message: "adsbygoogle.push() error: Only one AdSense head tag supported per page. The second tag is ignored." Am I the only one notice this on Wima MKP10 ? - Re-burn In - Page 13 - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Thread Tools
Old 15th September 2021, 11:59 AM   #121
NickKUK is online now NickKUK  United Kingdom
Originally Posted by wiseoldtech View Post
A while back, I un-subscribed to this thread, as I saw it was becoming another typical crap-fest.
The nit-picking, arguing, and obsessing over trivial nothings doesn't keep me entertained.
Oh well, back out.... have at it.
Stuffed with popcorn.
It would be interesting to see the different caps and their frequency phase shift over the frequency range tested.. especially in an amp with feedback.
V1 - low gain tube HPA OTL, fully balanced cascode 12BH7A, 12BH7A CCS, 12BH7A drivers and ECC99-BJT hybrid circlotron. (build)
V2 - pure digital tube HPA, RF-tube DSD512 modulation with mosfet output stage. (initial design)
Old 20th September 2021, 05:16 PM   #122
If you've not seen this: Graphs - WIMA – Competence in Capacitors
What is interesting is the 'general' ESR graph that shows the difference between metalised and foil.
Old 20th September 2021, 06:28 PM   #123
Fast Eddie D is offline Fast Eddie D  United States
I'm not going to slog through the crapfest so sorry if this has already been pointed out.
A well designed circuit wouldn't be so sensitive to minor changes in component characteristics.
Old 20th September 2021, 06:29 PM   #124
Old 20th September 2021, 09:16 PM   #125
johnmath is offline johnmath  Australia
I for one look forward to the days that such well designed circuits exist. Until and if that time ever eventuates, components will rightly continue to be selected on the basis of having the subjectively best compromise of characteristics for the specific application, as they have since the dawn of audio recording and playback, and in every other field of electronics.
Old 20th September 2021, 09:43 PM   #126
That's true.
However, there are many ways to mitigate the effect of component tolerance in some circuits. Do you know what the tolerance is on individual "components" inside an op amp? It's not 5%, that's for sure. Yet, they provide consistent and predictable performance.
On the other hand, many audio circuits (and other circuits) are dependent on tightly matched, close tolerance components. Example, a filter or crossover circuit; if the parts don't match closely, then the filters won't match from one channel or another; and in the case of a crossover, there will be a "hole" or overlap at the crossover frequency.
For higher order filters, this dependence on high tolerance closely matched components is compounded.
So, for a capacitor bleeder resistor, tolerance matters little. For a series output resistor, it matters more. For a filter, it becomes critical. I stock some resistor values in 2% tolerance, because for what I always use them for it's close enough. Most others are 1%.
Old Yesterday, 07:10 PM   #127
Pano is offline Pano  United States
Pano's Avatar
Burn in or rather "Reforming" of electrolytic caps is long known in the world of photo flash. If left idle for a long time, the storage caps in a flash will not fully charge, meaning under exposure - at least in older types of flash that didn't have fancy exposure meters. Running them thru a few charge/discharge cycles usually brought them back to full capacity.
I've never heard of anything like this with film caps. Perhaps the audible change came not from the Wimas, but from the PSU caps?
Lots of info about reforming electrolytic caps on the web, here is a nice page with good info. Rap on Replacing Electrolytic Capacitors
Take the Speaker Voltage Test!
  Reply to this post
Am I the only one notice this on Wima MKP10 ? - Re-burn InHide this!Advertise here!
Thread Tools
50x WIMA 0.33uF 250V MKP10 %10 Audio tube 330nF for TDA1541 umut1001 Vendor's Bazaar 2 3rd March 2011 03:05 AM
FS: Wima mkp10 2.2uf 400v dc capacitors 1.99$ each! umut1001 Vendor's Bazaar 8 8th November 2010 10:24 AM
WIMA MKP10 2.2uF Caps For Sale: $19 for 8, Free Shipping USA only Andersonix Swap Meet 9 16th September 2010 08:15 AM
Where Can I get Wima MKP10 4.7 uf in the US? KP11520 Parts 11 9th November 2007 01:26 PM
Wima MKP10 FKP10 Polarized? milanobardo Parts 2 26th January 2006 04:53 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
