Obsolete but still stocked at Profusion? SAP15NY Darlington Transistor | Profusion
Joined 2009
I have used a different type of Sanken Darlington, maybe they can be used in your application?
TGM6 - modified Pioneer HT amplifier
2SD2390
2SB1560
2SD2390
2SB1560
There is an alternative type: Sanken STD03N and STD03P I believe. Functionally the same but without the build-in Re.
Edit: Blocked
Jan
Thanks for the suggestion sorry for the silly question but what do you mean by Re?
Thanks bud but unfortunately they are the wrong channel I need PY's not NY's
2SD2390
2SB1560
Thanks bud I will have a look at your project!
Just thinking aloud: can´t you make a thumbnail sized miniboard and "build up" a functionally equivalent discrete replacement?
That could be a fun idea! I have the skills just not sure the brain to work it out XD
No external diode is as well and rapidly coupled to die temperature as the built in one
Sorry could you explain more?
........Re: emitter resistor (mostly 0,1.........1 ohms) is inside the case of the sap transistors (see data sheet), that is uncommon.
and the thermal tracking diodes are also inside the case - should give the fastest reaction if temperature changes........
Ah I see thank you!
Yes. In the original transistors, the build-in Re used to break too easily on overload, way before transistor itself would break. So they came out with the STD series that is internally identical to the originals, including the clever sense diode arrangements, but without the Re.
So you can replace the originals with the STD but you would need to add the Re resistors externally between two of the pins. It will all be clear when you compare the internal circuitry from the data sheet.
Jan
Jan
That is the solution, even better than originals.There is an alternative type: Sanken STD03N and STD03P I believe. Functionally the same but without the build-in Re.
Edit: Blocked
Jan
Adding external resistors is *relatively* easy, we need some closeup pictures to see what space you have available.
At least one from component side, one from copper/tracks side, you will need to cut one track and scratch soldermask (the typically green "paint" covering copper) to solder a couple wires to the added resistor.
As of:
Sure, nobody argues that.No external diode is as well and rapidly coupled to die temperature as the built in one
That said, IF no internal diodes were available , external sensing would have to do.
A viable alternative used by most other amps.
Jan
I see that seems like a better than the original solution then thanks!
As of:
The re-work will be no issue I am an NPI Tech for a PSU company so everyday I'm putting components and laying tracks where they don't belong!
I will get some pics of the board up asap
Thanks everyone!
- Design & Build
- Parts
- SAP15 Darlington Transistors
