Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Which of these ICs can be swapped out with the OPA2134?
Thread Tools
Old 20th July 2021, 10:59 AM   #11
Mark Tillotson is offline Mark Tillotson
Originally Posted by saabracer23 View Post
So the OPA2134 will not need the decoupling then is what youíre saying?
No, just that this is one of the many things you need to check before substituting opamps - you can't just expect any opamp to work in a particular circuit, you have to read the datasheet carefully (just like any active component).
Old 20th July 2021, 12:23 PM   #12
kn0ppers is offline kn0ppers  Germany
Out of curiosity, is there a matching single op amp for the 1656? As in for the OPA2134 there is the OPA134.
I think there were plans from TI but I haven't heard anything in a while...
Old 20th July 2021, 05:50 PM   #13
saabracer23 is offline saabracer23  United States
Oh okay, thank you for the clarification.
By looking at the schematic, what devices would benefit from being changed? Should I do all of the LF353N? All of the RC4558P? Should I get some OPA134 for the LF351N?
Dan
Old 20th July 2021, 07:15 PM   #14
00940 is offline 00940  Belgium
00940's Avatar
No but you have an OPA1641 which is quite a bit better than the OPA134. As already suggested by Jean-Paul... There is a whole family of opa1641-1642-1644, just as for the opa134.
All that is excessive is insignificant. Talleyrand
Old 21st July 2021, 01:33 PM   #15
Okay perfect, thank you.
Dan
Old 21st July 2021, 01:34 PM   #16
Is anybody able to look at the schematic at determine what device numbers should be the ones replaced?
Dan
Old 21st July 2021, 03:29 PM   #17
Originally Posted by jean-paul View Post
OPA2134 is good ... but it consumes more power than normal (8 to 10 mA per IC) and it is not rail to rail output. OPA1642 is its replacement despite the lower type number. It needs an adapter though.
Easiest is to replace LF351N and LF353N for the OPA134 and OPA2134 just like the shop in Idaho did. To judge things right with the other opamps the schematic is a must.
Iím not certain thatís what the shop did, I couldnít even venture a guess. Do you believe that is likely what they did, are those the ICs you would replace?
Dan
Old 22nd July 2021, 01:49 PM   #18
Dan
My question again: what performance is currently lacking that you want? Do you have any means to measure it?
Old 22nd July 2021, 02:04 PM   #19
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Full of conviction I assume the guys at DBX knew very well what they were doing and why they chose the 4558 at which position in their circuitry. Yes, I know of the not-so-good fame of this device. Anyway, there are applications where it simply is hard to outperform it. Last but not least don't forget that we're discussing a FX device here, not a high end reproducer.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Old 22nd July 2021, 02:05 PM   #20
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
They likely chose the opamps for their low price as usual. Same reason NJM4580 is found in abundance.
It's only audio. Member of the non modular PCB design committee.
Which of these ICs can be swapped out with the OPA2134?Hide this!Advertise here!
Thread Tools
Oscillating swapped OP Marmotus Solid State 10 3rd May 2019 11:21 AM
Cascode VS Wilson Swapped Mirror TzeYang Solid State 4 9th July 2008 03:24 PM
Noise floor rise on heathkit W4-AMs when power supply transformers were swapped terminatorx Tubes / Valves 4 8th October 2006 01:31 AM
swapped OPA2132 for AD8620... dorkus Digital Source 15 22nd January 2006 09:01 PM
HELP! i swapped plus and minus! Smithers Pass Labs 10 5th January 2003 02:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
