Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Abbott Transistor DC Converter?!?
Thread Tools
Old 2nd May 2021, 09:53 AM   #1
Quantensprung is offline Quantensprung  Germany
Default Abbott Transistor DC Converter?!?
Hello diy fellows
I have several of very solid build Abbott Transistor DC converter, filter or maybe choke. I could not find any information about this special part and also did not found something with similar specs from Abbott Transistor. Would be really great if you can help me identifying what this thing exactly is.
Here are two pictures. These are shared on my google drive as I do not know how to upload pictures directly from an iPhone.
IMG_0152.jpg - Google Drive
IMG_0147.jpg - Google Drive
Kind Regards and thanks in advance
Phil
Old 2nd May 2021, 10:54 AM   #2
duncan2 is offline duncan2  United Kingdom
Your in luck Abbot Tech still support legacy DC to DC converters -
DC to DC Converters - Abbott Technologies
Old 4th May 2021, 07:04 AM   #3
Thanks for the information but I couldn’t find any specific docs about my unit. As input and output voltage range are same I do not know what it really is and it’s usage. As I have at least 5 pieces it would be great to know if I can use them in audio power supplies. The amp rating is about 20 amperes.
Old 4th May 2021, 11:23 AM   #4
Used in audio its all down to noise & ripple from the output --when under load ,at 20 amps I don't think you will have a current supply problem its just down to the output noise .
Check the output with an oscilloscope or if not a wideband millivolt meter on the AC range .
  Reply to this post
Abbott Transistor DC Converter?!?Hide this!Advertise here!
Thread Tools
Can I build up these Darlington transistor if I use two BJT transistor ? gaborbela Parts 27 25th November 2020 04:20 PM
What makes an audio transistor an audio transistor? pound Instruments and Amps 5 25th April 2019 12:51 PM
Do I need a step down converter and a Isolated converter crisd1 Power Supplies 6 18th January 2019 03:51 PM
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
One driver transistor per output transistor possibilities? rhythmsandy Solid State 25 27th October 2014 11:11 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
