Those old Rifa caps are metalized paper - they can be replaced with either polyester or polypropylene units of equivalent value. Appropriate safety rating is probably X2. The usual distributors should have them. Be generous with the voltage rating, and they will last longer.
These are the "self-healing" X-cap while these old Rifa were the "self-exploding" caps.BTW I've hade many mains rated X2 capacitors lose their capacitance in triac controllers due to corona effect.
The failure mode is described e.g. here.
what about the currently available "RIFA" branded successors from KEMET regarding reliability and life time ?It looks fine but shows as out of stock for me. These caps are not critical apart from having to be safety rated.
You can just snip the old one out for now, it doesn't need it to work. M can mean 20% tolerance (not critical here) and MP could be Metalized Polyester (the type).
https://cpc.farnell.com/vishay/bfc233620103/capacitor-class-x2-0-01uf/dp/CA07137
https://electronics.stackexchange.com/questions/437683/rifa-pme271m547-replacement
