Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Oil filled chokes 12,5H
Thread Tools
Old 3rd March 2021, 06:22 PM   #11
egellings is offline egellings  United States
At 210 ohm DCR, the chokes may well have gotten quite warm in use, and the oil would transfer heat out of the windings. Just a guess.
Old 3rd March 2021, 07:05 PM   #12
Pano is offline Pano  United States
Pano's Avatar
Thread title fixed
Old 3rd March 2021, 09:25 PM   #13
trobbins is offline trobbins  Australia
trobbins's Avatar
I recommend you spend the time and do some testing of how the inductance varies with dc current and AC voltage, and do an insulation resistance measurement at 1kVdc. That would then provide confidence on how well and safe those parts can be used in upcoming projects. Vintage chokes like that could be designed for CLC or LC filtering, and the rating plate doesn't identify that or the maximum dc current capability.
Inductance testing can be DIY:
https://www.dalmura.com.au/static/Ch...easurement.pdf
Old 4th March 2021, 12:21 AM   #14
daqvin_carter is offline daqvin_carter  United States
It may be worth making sure the chokes still have oil. Seals can fail and slowly let the oil out. Maybe carefully weigh both and make sure they weigh the same.
Sort of fun to see something with oil filled capacitors or chokes and notice dried oil under the terminals.
Old 4th March 2021, 01:38 AM   #15
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Yep. The fact that it says "60Hz"on them may mean they are not intended for DC. How big are they physically?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
  Reply to this post
Oil filled chokes 12,5HHide this!Advertise here!
Thread Tools
Oil Filled Transformers for BOZ and Valve Preamps mozfet Swap Meet 3 31st October 2002 10:13 AM
Parmeko Oil Filled Transformers Tube (Valve) Power Amp 110V up to 250V mozfet Swap Meet 5 29th October 2002 10:57 AM
Partridge Oil Filled C-Core Chokes 1H @ 500mA mozfet Swap Meet 1 28th October 2002 07:27 PM
Oil Filled Transformers Valve Filaments or Solid State Equipment mozfet Swap Meet 2 28th October 2002 07:22 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
