Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
help sourcing binding post
Thread Tools
Old 3rd December 2020, 12:43 AM   #1
ultrachrome is online now ultrachrome  United States
Default help sourcing binding post
I have an old Topward DC power supply that has some broken binding posts.
I'm looking for help sourcing a suitable replacement.
The shaft is 10-32 and approx 1-9/16" long. It need to be this long as it passes through two PCBs that are spaced 1/4" apart. 1-7/16" is the minimum length that would work.
Thanks.
Old 3rd December 2020, 01:17 AM   #2
rayma is online now rayma  United States
Sounds like you need a speaker style binding post. There are many to look at.
Old 3rd December 2020, 01:29 AM   #3
I've looked but the few I've found that are long enough are metric with a larger diameter shaft. I really need 10-32 as the 1/4" spacer between the PCBs that the stud must pass through is threaded.
Wondering about just buying 10-32 threaded brass rod. I can probably live without banana compatibility.
Was hoping someone could identify the manufacturer by the knob style. I've not come across this style in my image searches.
Old 3rd December 2020, 01:34 AM   #4
The 10-32 brass rod stock (or bolts) are easy to get.
Can you replace the threaded spacer with a clearance spacer?
Old 3rd December 2020, 02:05 AM   #5
I'd have to de-solder and remove all 8 binding posts which would be time consuming.
However, of all the speaker binding posts I've found, I'd have to enlarge the PCB pads through which the posts pass through which seems like a risky plan.
Old 3rd December 2020, 02:07 AM   #6
Yes, I'd go with the 10-32 rod stock, if workable.
Old 3rd December 2020, 02:31 AM   #7
Enzo is offline Enzo  United States
Can you not enlarge the holes for the larger metric shaft newer ones?
Old 3rd December 2020, 06:50 AM   #8
myleftear is offline myleftear  Switzerland
myleftear's Avatar
024-2010 ELMA binding posts 2099004589
dobedobedo...
Old 3rd December 2020, 11:12 PM   #9
Originally Posted by myleftear View Post
Hadn't looked at that vendor yet but these have two strikes: too short, and metric.
Decided to order some 10-32 threaded brass rod and 1" threaded coupler from Mcmaster.
The standoff can double as a banana jack or I can even thread in a binding post.
  Reply to this post
help sourcing binding postHide this!Advertise here!
Thread Tools
Dayton binding posts and binding plate diypass Multi-Way 13 27th May 2019 08:27 PM
Please help find binding post part Jockaruba Parts 3 8th December 2014 05:15 PM
Sourcing Compact Binding Posts lucadelcarlo Parts 1 25th May 2009 01:58 AM
Binding Post Crossthread, Help!! dmongrain Parts 6 23rd February 2009 09:27 PM
Help needed with sourcing active crossover parts Thunau Parts 8 11th April 2003 11:15 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
