Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
fake epcos snap-in capacitors?
Thread Tools
Old 27th October 2020, 08:06 AM   #1
SoundFlower is offline SoundFlower
Default fake epcos snap-in capacitors?
So recently i purchased some EPCOS capacitors online from a local store which is not an authorized distributor for TDK, but seems to have lots of different known brand items in the store and is well reviewed. When the capacitors arrived, i noticed they deviated a bit from the datasheet. they don't have the "PET" marking on the sleeve as described in the datasheet, and the pins are attached to the capacitors in a different position. I'm attaching pictures of the capacitors in case any of you are familiar with the brand and have purchased confirmed originals and know if they look like these or not. At the moment i don't have a way to measure them, and when i contacted TDK, they basically told me to look at the datasheet, which i had mentioned to them i already had.
Thank you!
Old 27th October 2020, 08:42 AM   #2
ubergeeknz is offline ubergeeknz  New Zealand
Which store?
Old 27th October 2020, 08:57 AM   #3
Also I'm not sure that it isn't genuine.
Are the terminal pins the correct distance apart (10mm from memory) - I don't recall ever having seen the letters PET on an EPCOS cap either (I buy from a reputable source, RS Components) so that may be a red herring.
I'll see if I have any pics or any in stock.
Old 27th October 2020, 09:29 AM   #4
Found some here, terminals are also like yours and no lettering. So I don't think there is any visual indication yours aren't genuine. Sorry, a bit hard to see in the photos as they're already installed to a terminal strip here.JPEG_20201027_212722_3838566290850526431.jpgJPEG_20201027_212853_2488603249634330300.jpg
Attachment 888033
Old 27th October 2020, 09:51 AM   #5
Originally Posted by ubergeeknz View Post
Which store?
it was an online store in mercadolibre in colombia.
and thank you for the pictures, they make me feel more comfortable with the purchase, ans they do look like the terminals are attached to the capacitor in the same way as mine, i still think it's odd they don't look like the ones in the datasheet.
thank you!
Old 27th October 2020, 09:57 AM   #6
a007udio is offline a007udio  Europe
This one is from Mouser. Its different version, but your looks good to me.
Old 27th October 2020, 11:25 AM   #7
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
And WHERE is "local"?
Please fill location/country data in your DIY Audio member page.
EDT: quite certain "PET" means the white strip showing negative terminal.
Which is clearly seen both in your picture AND in the datasheet image , and in the exact same angular position, on the same diametral line joining both terminal tips.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 27th October 2020, 12:46 PM   #8
ferret is offline ferret  South Africa
ferret's Avatar
Quote from TDK Techinfo section 3.8.1:
" PVC insulation and PET insulation cap on terminal side
For capacitors with snap-in terminals we offer offers an insulation version with an additional PET insulation cap on the terminal side, which is placed underneath the shrinking sleeve to increase the creepage distance. This is a special design for applications with uninsulated live parts under-neath the capacitor, where higher grade of insulation is required. Dimensional details are given in the detailed specification of the corresponding capacitor series. While this design offers improved characteristics with respect to creepage distances, but it is not to be considered as functional in-sulation."
link - https://www.google.com/url?sa=t&rct=...t4FoLOvmmuEoG9
Ferret. - Gaya rules
Old 28th October 2020, 06:51 AM   #9
thank you! those pins looks like mine, and also missing the "PET" marking. i guess they just deviated from the datasheet with those details.
And regarding the other replies here, the datasheet clearly mentions the letters "PET" being printed on the sleeve, which was where my wondering came from.
Old 28th October 2020, 10:02 AM   #10
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
PET refers to the type of plastic used in the sleeve. Nothing else.
Polyethylene Terephthalate.
It describes a hard but durable plastic that is resistant to most chemicals and reasonable heat up to 120℃
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
  Reply to this post
fake epcos snap-in capacitors?Hide this!Advertise here!
Thread Tools
EPCOS/TDK electrolytic capacitors diyralf Parts 9 1st January 2018 04:12 PM
EPCOS/TDK Capacitors fabrice63 Parts 0 1st August 2016 03:14 PM
Epcos SMD 100 nF 1206 X7R capacitors jean-paul Swap Meet 3 8th May 2006 07:12 PM
Snap-in Capacitors 10,000 uF 35V Nichicon 96 Pcs. Michael Rothacher Swap Meet 1 29th October 2005 11:54 AM
WTD: Epcos B25839 Capacitors seta4545 Swap Meet 0 27th June 2004 02:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
