Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Dual or quad secondary transformer.
Thread Tools
Old 18th September 2020, 06:00 PM   #1
mchambin is offline mchambin  France
Default Dual or quad secondary transformer.
Are they mains transformers with two equal voltage center tap secondaries ( 6 terminals at the secondaries ) ?
Or a variant four equal voltage secondaries ( 8 terminals at the secondaries ).
This is just to know wether this is popular or asks for a custom winding.
Transistor junction temperature is not transistor case temperature.
Old 18th September 2020, 10:01 PM   #2
Vovk Z is offline Vovk Z  Ukraine
It's a bit hard to understand your question for me, but if understand you right: you ask about whether to order a transformer with center tap or isolated windings? The answer is usually - It is almost the same for manufacturer, so you may order a variant you need.
With center tap it is only a one wire cheaper for a manufacturer.
(As for me - I prefer isolated windings).
Old 18th September 2020, 10:12 PM   #3
ohdsp is offline ohdsp
If I understand you want to know if 4 winding transformers are common - either 4 individual windings or 2 center tapped windings.
I would say no. Most are 2 windings, or 1 center tapped. If you pull up something like Farnell all their parts are 2 windings. If you want 4 custom would be the way to go.
Also idividual windings are more flexible than a center tapped type.
Check out the Open Hardware DSP Platform - modular board designs for audio DSP use. Current projects: 2 in 8 out 192kHz/24bit DSP crossover box, CoreOne - Xmos XCORE200 (Ethernet and USB). http://www.ohdsp.org http://github.com/ohdsp
Old 18th September 2020, 11:51 PM   #4
This means: To make a dual rail PSU,
+V Ground -V, using two identical regulated PSU, with a common transformer....The only way is a two windings transformer with two diode bridges.
The extra cost of a custom transformer is likely more than the saving on 4 diodes instead of 8.
Old 19th September 2020, 12:06 AM   #5
You can use two winding transformers with 1 bridge rectifier, just join the two windings together to give you the center tap (observing phasing), use the connection between windings as 0V/ground, then the other ends go to the AC connections on the bridge rectifier, then just one set of capacitors.
However two bridge rectifiers should be better, you can get a lot of current flowing in the "center tap" (where you join the two windings, allegedly, i've never measured it). Then join the + and - of the two bridges to give 0V.
Drawing schematics might be clearer, too many though...
Old 19th September 2020, 01:36 AM   #6
You missed the requirement: Using two identical regulators.
In other words, I do not want to use a positive regulator and a negative regulator. I want to use two regulators of the same polarity.
Then you cannot join the + and - of the two bridges to give 0V.
Old 19th September 2020, 11:11 AM   #7
Ah yes, in that case you will need dual windings, or if you did find dual centre tapped windings you would ignore and leave the centre tap disconnected, and use in the same way.
  Reply to this post
Dual or quad secondary transformer.Hide this!Advertise here!
Thread Tools
How to get dual rail psu from single secondary transformer nenad88 Power Supplies 16 9th February 2020 07:47 PM
dual secondary transformer connection ? dorsetpaul Power Supplies 17 18th January 2020 09:59 AM
50VA Toroidal Transformer Dual Primary 120/120 and Dual Secondary 15/15 KatieandDad Swap Meet 3 11th February 2012 07:26 AM
Plitron 300VA 18 + 18V (dual secondary) transformer bmwpowere36m3 Swap Meet 5 20th January 2010 04:26 PM
dual secondary transformer connected in series Leolabs Solid State 2 7th October 2006 12:38 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
