Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What are these screws called?
Old 14th September 2020, 03:02 AM   #31
K-amps is offline K-amps  United States
Originally Posted by Cal Weldon View Post
I don't see where anyone has paid attention to this.
This is what I will use as a search term. Thanks guys!
I also appreciate the tips on Tapping... just not my thing at the moment.
Old 14th September 2020, 04:32 AM   #32
oohms is offline oohms  Australia
Tapping aluminium is super easy and very consistent after a little practice. Just make sure to use the right size drill, then wind the tap in and out, brushing the excess from the channels in the tap and using cutting/tapping fluid (or olive/canola oil) while doing so
After a while you can freehand both the drilling and tapping with a cordless drill
With self tapping screws you are entirely dependent on the quality of screw to both easily tap the hole and not snap off
Old 16th September 2020, 12:40 AM   #33
Good advice.
Rookie question, what is the percentage of success with or without cutting oil?
Old 16th September 2020, 06:46 AM   #34
Vovk Z is offline Vovk Z  Ukraine
There is no need at all to work (to tap) without some lubricant (I use an alcohol or an oil for aluminium), because it became harder and quality may go out of your control.
I don't like oil (because it is oily ) so I use an alcohol with an aluminium - it leaves no oily trace. (I use the same liquid as for cleaning the PCB - a mixture of an isopropil alcohol and a clean gas/gasoline).
There is of cause some difference between an oil and an alcohole but for DIY-tap it works about the same.
  Reply to this post
What are these screws called?Hide this!Advertise here!
What are these called, and where to get them? Dmitryy Parts 1 17th December 2018 05:29 AM
What is this called and where can I get them? awdtalon21 Parts 5 19th October 2018 05:24 AM
what is this called and can you get them garybdmd Parts 2 10th November 2017 06:12 PM
Anyone Know What This Is Called And Where I Can Buy Them? 2MuchRiceMakesMeSick Parts 4 11th February 2012 06:26 PM
what is this called skullkeeper Parts 1 23rd April 2009 11:28 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
