Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
fasteners used in old Pioneer valve amplifier
Old 27th June 2020, 07:00 AM   #1
dickyknee is offline dickyknee
Default fasteners used in old Pioneer valve amplifier
Hi all,
I'n new to the group, recently joined to seek some information on my current project.
I'm in the process of rebuilding an old Pioneer SA-400 amplifier and am having trouble identifying the fasteners used through-out the unit. They're not standard metric threads, though the verniers measure the diameter of the 2 sizes used as 3mm/4mm. most of them are self cutting screws, but even the ones that aren't have the same thread.
They don't seem to be BSW or UN threads either. I've been down to the local screw shop and they are also unable to identify them.
is anyone able to help identify the screws?
thanks.
Old 27th June 2020, 07:18 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Most were course metric but some were UNC.
Use a thread gauge to measure the size.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 27th June 2020, 09:14 AM   #3
Thanks for the feedback. it seems in this case that they are neither metric threads or UNC and normal thread gauges can't identify them.
worse case if I can't figure them out is to drill the chassis threads out and replace with standard hardware..
Old 27th June 2020, 09:49 AM   #4
russc is offline russc  England
Possibly JIS?
Talk:ISO metric screw thread - Wikipedia
Astonishingly, screws are available on Ebay.
Old 27th June 2020, 10:42 AM   #5
MAAC0 is offline MAAC0  Portugal
I usually use self tapping 2 or 3 mm screws on steel or metal and they work fine.
You must be careful when it comes to fasten on plastic parts or You end up breaking something.
Perhaps I would use Inox types on the outside in order not to rust.
  Reply to this post
fasteners used in old Pioneer valve amplifierHide this!Advertise here!
​Can a Pioneer GM-A3702 Two Channel Amplifier drive Pioneer TS-W306R 12-inch Subwoofe Peter Wan Car Audio 5 4th May 2018 03:22 AM
Pioneer SA-400 Valve Amp Volume Pot needed Methusala Parts 2 11th September 2015 10:58 AM
Fasteners for transformers? subwerker Parts 4 3rd March 2014 11:04 PM
Flathead Fasteners GOR3 Parts 2 30th April 2012 07:27 PM
grill fasteners Thomas Torretto Multi-Way 2 15th June 2001 04:27 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
