Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Signal-dependent cable capacitance change
Old 21st June 2020, 05:57 PM   #21
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
If I read it correct, the inductance variation in the headphone cable due to the current is about 0.5nH. A tall order to translate that in audible differences.
Jan
Old 22nd June 2020, 02:37 AM   #22
davidsrsb is offline davidsrsb  Malaysia
These papers do seem to be demonstrations of tiny parameter changes and then make a huge jump to blaming these for audible differences.
The experimental measurement methods could do with some justification too.
Headphone cables are usually copper for flexibility, so where is an inductance change coming from unless it is thermal
Old 22nd June 2020, 04:17 AM   #23
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by davidsrsb View Post
...a huge jump to blaming these for audible differences....
The Headphone paper has a interesting Table 2.
I have heavily edited and compressed this passage to point-out what I am critiquing; you really want to read the whole paper for context (and easier reading).
He digitally modified music files with the effect he proposes, in degrees from 1ppm to 1,000ppm. He asked 9 young people to listen to the raw track, then find other tracks which "sound different". His Table 2 says that nearly all subjects could hear 1,000ppm (m3/p3), some heard 100ppm or less, none heard 1ppm. And oddly, none heard difference for the identical file.
Old 22nd June 2020, 07:18 PM   #24
jneutron is offline jneutron  United States
jneutron's Avatar
Jan
The leading edge of a fast slew will skin the current, so the inductance during slew will be reduced a maximum of 15 nH per foot per conductor. When the slew is over, the current will redistribute to uniform cross section and the wire during that time will store inductive energy from the signal current.
.5 nH is trivial in that context.
Measurement of a twisted pair induces that as well as proximity. As the current redistributes after a slew, many meters can misinterpret the additional system energy storage as capacitive effects.
Twisted pair in open air also has capacitive coupling based settling after a slew. The understanding of all the actual effects, how they confound the measurements, and the resulting conclusions...sigh.
None of this is really of use, the paper authors need to revisit the blackboard..
Jn
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 23rd June 2020, 06:33 AM   #25
Jn
This is a linear effect and gives a frequency sensitivity. The page extract above
describes an effect depending on the square of the current, is non-linear. Where that comes from is not explained so far in this thread
If susch an effect is real and prumably causes a second harmonic, I find it hard to believe that any listeners could hear 0.01% 2nd.
Second harmonic has to be well above 1% to be obvious
Old 23rd June 2020, 01:59 PM   #26
jneutron's Avatar
When an effect is dependent on both level of current and it's derivative, and the mechanism is storage (LI^2 or CV^2), most people have no idea how finicky the measurement technique becomes.
I pointed out how slew dependent inductance of a wire pair (which was not considered) exceeds the "odd" result mentioned by a factor of 60.
So, nah, nothing odd in the tests, just the understanding, methodology, and conclusions.
It is very difficult to explain someone's test and theory error long after the fact. I would have to be there examining the setup, using methods to check the test results.
I do applaud the effort however.
As a fun note...I am currently in the process of building a metal detector, the goal is to find an aluminum plane buried under 65 feet of sediment, with 70 feet of seawater above that.
It involves a 20 foot diameter coaxial cable search coil, a tigersaurus 250, and a spectrum analyzer to spot third harmonic eddy current dissipation..
It is scary what one gets involved with friends during a lockdown...I chose a sine excitation for the search coil, as I worry that microsecond tens of amps pulses applied to a 20 foot coil might involve some explanations to homeland security...we already warned the harbormaster...
Jn
  Reply to this post
Signal-dependent cable capacitance changeHide this!Advertise here!
Cable capacitance east electronics Solid State 33 11th February 2020 08:00 PM
what to consider when you have 500ft of speaker cable how to deal cable capacitance? rhythmsandy Solid State 19 12th August 2014 01:01 PM
How to change phono input capacitance on Rega Brio r Ale79 Analogue Source 3 28th April 2013 02:02 PM
phono cable capacitance thetube0a3 Analogue Source 11 24th February 2012 08:40 PM
Cable capacitance Prune Everything Else 7 8th February 2004 10:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
