Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Best TIP42 for audio
Old 28th March 2020, 06:01 PM   #11
keilau is offline keilau  United States
Originally Posted by Monte McGuire View Post
The New Japan Radio versions seem to be the nicest (e.g. lowest distortion). This would be the NJM5532D and the selected version NJM5532DD in the DIP-8 package. I think they gave up on the single 5534 version though.
Honestly though, an LM4562 beats the daylights out of a 5532, and is very inexpensive too.
Single ICs to replace a 5534 will be tougher to find now. The only time singles get made now are when the idle dissipation for one amplifier is on the high side, making a dual harder to use.
Totally agree with you on the LM4562. I use LME49720 ordered from DigiKey.
Single ICs to replace a 5534 is difficult to find at reasonable cost. I paid $6 per piece for the LT1115 and consider it very good price.
Old 29th March 2020, 04:51 AM   #12
sgrossklass is offline sgrossklass  Germany
And then you still need to make sure that the application actually plays to the part's advantages... which mostly means low source impedances in this example. In a phono MM application, results would be rather tragic in the noise department.
Old 29th March 2020, 07:17 AM   #13
altec9440 is offline altec9440  France
I ordered pieces from each brand.
Hope that locky_z will offer a new curve tracer in order to test these samples
Old 29th March 2020, 02:03 PM   #14
Default single op-amp in DIP-8
I ordered the LT1115 for Wayne Palmer's moving coil phono stage build, not for 5534 replacement. I just use it to show that very few single op-amp in DIP-8 were available. I have not used a MM cartridge for a long time.
Old 30th March 2020, 04:40 AM   #15
Monte McGuire is offline Monte McGuire
The LT1115, LT1028 and AD797 are all super high input stage bias current op amps, part of the reason why a dual of these amplifiers is not feasible. As was mentioned, their input current noise will likely be the dominant noise source in a MM phono application - they're great amps, but their input stage is optimized for impedances closer to 50-70Ω, far enough away from a MM cartridge to be annoying noise-wise.
What might make the best sense for a 5534 replacement these days is to rig up an SO-8 package LM4562 / LME49720 dual on an SMD adapter as a single with the other half wired "off". At least then you could use an amplifier that makes sense as a 5534 replacement.
Best TIP42 for audioHide this!Advertise here!
How to distinguish counterfeit TIP41 and Tip42 from the genuine? agentgates Parts 16 11th May 2016 01:58 AM
ST TIP41 / TIP42 DATASHEET ANOMALY? gasboss775 Parts 2 24th February 2015 09:25 PM
Simple high quality audio amp using tip41 & tip42 rrbadrike PA Systems 6 15th December 2013 11:10 AM
Problem with tda2030a+tip41/tip42 120w amp rrbadrike Solid State 6 1st April 2012 10:20 AM
Transistors: D1047,TIP42 -> pinout ? ghg Parts 4 18th August 2011 05:34 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
