As title says, I'm looking for ~1.5-2mm thick steel mesh (no skimpy aluminum or thin steel) with 5-6mm holes, around 14x30 (can cut down if larger, or perhaps custom order?)
I found one example on Parts Express, but not sure if it's close enough to match some EAW's.
Parts Express Flat Metal Grill Pair with 6mm Round Holes - 22" x 30"
If nobody chimes in, I will just order that since at >10' away you can't tell anyways I feel ...
Thanks!
Thanks!
Check out McNICHOLS(R) | Perforated Metal, Wire Mesh, Bar, Plank, Fiberglass Grating. Great selection, warehouses all over the US. I had good experiences with them. E
- Design & Build
- Parts
- Looking for 90's EAW-style steel grill (5-6mm holes)
