Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Low noise high voltage mosfet or jfet
Old 21st March 2020, 05:42 AM   #11
sgrossklass is offline sgrossklass  Germany
For therecord, we're talking about the amplifier from this thread.
Old 21st March 2020, 01:52 PM   #12
Frederico Acardi is offline Frederico Acardi  Italy
Thank you everyone.
Yes it's this preamp. I will replace the 1M potentiometer in this circuit by a 5K one if possible.
But I did not post it because I wanted to know the theory also. I did not want to only have the suggestion and basta. I was affraid you guys will probably say, you don't need a low noise part everything will work fine.
That is why, sorry.
Originally Posted by PRR View Post
Do you have 300 Volt signals?
Having 350V when you need 30V is a minor problem. There are many ways to reduce DC voltage, and you can also design-in filtering.
How can I do this without adding too much noise (or lowering the first gainstage also)
Old 22nd March 2020, 02:58 AM   #13
PRR is offline PRR  United States
PRR's Avatar
Frederico-
If the Altec preamp is "noisy", you are using it wrong.
However, just because something is vintage does not mean it is good.
Old 22nd March 2020, 02:42 PM   #14
davidsrsb is offline davidsrsb  Malaysia
Low to high impedance step up transformers are something to be avoided. A good one with better than dire frequency response and low frequency distortion is very expensive
Solid state does a better job of matching low Z microphones than valves ever can
Low noise high voltage mosfet or jfetHide this!Advertise here!
Lowest voltage noise dual JFET op-amp kaquino215 Chip Amps 8 2nd January 2011 12:54 PM
SWM Seeking JFET /w low noise + high Vp aletheian Solid State 3 11th July 2007 12:18 PM
Ultra low noise JFET voltage regulator Kochkurov Maxim Digital Source 6 25th January 2004 11:33 AM
High-Voltage JFET IIR Solid State 3 20th December 2002 08:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
