Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need Help with part on PCB board
Old 26th November 2019, 05:28 PM   #11
Trdat is offline Trdat
Originally Posted by Boydk View Post
FB = BFP17. Itīs "through hole" equivalent is BFW92
I found the part with the number BFW92 in Mousser and Arrow but they are not available.
I will email to see if they have an equivalent.
This is especially helpful if on the off chance I don't find a donor board.
Old 26th November 2019, 05:34 PM   #12
Originally Posted by indianajo View Post
Yes sorry, thought R3 must be a resistor. 3 pin devices are usually transistors. you might measure one in a similar posistion to see if it is npn or pnp. The pin that has the 400 to 700 mv drop on diode scale to the other two pins is base. plus from base to E & C is npn. minus is pnp.
Best thing if it is under 31 days is ask to return it for refund. If you broke a QA seal taking the case off you violated the warrenty.
Mate the bluetooth is so cheap its probably not worth it but like I said I might possibly learn a lot just from this small burnt out transistor. So I am analysing all the posts above. I appreciate your comments....
Regarding warranty they have sent another one, but I am wondering if I can salvage this if possible.
I know, i said R3 and only later saw there was more codes above. The explanation by pilli clarified a lot more.
Old 26th November 2019, 05:54 PM   #13
Boydk is offline Boydk  Denmark
BFP17 pricing list,BFP17 datasheet|transistor mosfet|transistorall.com
Old 27th November 2019, 01:35 AM   #14
Mark Tillotson is offline Mark Tillotson
Looks like a dual schottky clamping diode. Very standard for input protection, clamps the incoming signal to within the power rails. If a large signal was present with the device powered down I might expect it to fry if the resistor before it wasn't large enough in value, since the signal is then trying to power up the board (phantom powering).
You can test this theory by seeing if two of its pins connect to each supply rail.
Old 27th November 2019, 08:04 AM   #15
Mooly's Avatar
Hence:
Originally Posted by Mooly View Post
You could also try removing it completely and seeing if the stage now works.
I also wonder (and it is really hard to tell with pictures) whether it is actually fried at all, or whether it is just a damaged part that has been placed during manufacture.
Need Help with part on PCB boardHide this!Advertise here!
Power Acoustik BAMF 5500 driver board part number imraneesa Car Audio 62 2nd February 2019 09:46 AM
TI OPA1622EVM headphone driver eval board unboxing and hookup, part 1 agdr Headphone Systems 21 3rd October 2016 05:09 AM
Looking for help identifying burned up part on Crate PA4 circuit board davelang68 Solid State 10 30th October 2012 11:47 AM
Krell KPS-20i CDM Servo Board Part? audiosurfer2007 Vendor's Bazaar 5 30th January 2012 11:17 PM
Need part # for 30-pin connector part inside Logitech Transporter on front panel PCB Bellatone Digital Source 4 27th April 2011 08:39 PM
Copyright ©1999-2019 diyAudio
