Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need a replacement relay for this amplifier. It's 24v DPDT but I can't seem to find the right pin size and configuration? If anyone else has figured this out and can tell me what they used in their AU-5900, AU-6900 or AU-7900 it would be much appreciated. The original is obsolete, although I saw a second hand one on fleabay for $US65 including postage. lol
#2 |
https://www.digikey.co.uk/products/e...ds=MY2-02-DC24 looks like a good modern replacement or
there are many models to choose from. The part number you need to google is RABK-2B 24volt Hope that helps but if you remove the relay, unclip the case and clean the contacts, it will be good for another 30years.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk |
#3 |
The left contact was twisted out of alignment? I bent it back but a new MY2-02-DC24v relay is going back in to be sure. Thanks Jon.
Thread | Thread Starter | Forum | Replies | Last Post |
Need Equivalent 2SC711F ( in sansui au-5900 ) | Nagal | Parts | 5 | 18th July 2019 03:38 AM |
Sansui AU 5900 dead channel | Depaj | Solid State | 50 | 19th November 2016 11:02 AM |
Sansui AU-70 - Help Needed | Dev0n | Tubes / Valves | 8 | 12th August 2014 10:40 PM |
Protection Relay Closes Too Fast on Sansui G-7000 Receiver | Zekeman | Solid State | 0 | 16th December 2013 04:17 PM |
Tuner Sansui TU-5900 | Ciu | Analogue Source | 0 | 10th May 2007 11:22 PM |
New To Site? | Need Help? |
