Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What is the value of this variable resistor ?
What is the value of this variable resistor ? Please consider donating to help us continue to serve you.
Old 23rd November 2019, 10:12 AM   #11
Nounours18200 is offline Nounours18200  France
The measurement current is small, and even if it isn't absolutely accurate, it's enough to see if it is 200R or 600R. Did you try?
Here are the measurement I performed this morning (without desoldering):
LEFT channel:
pin1 -> pin2 = 122 ohms
pin1 -> pin3 = 219 ohms
RIGHT channel:
pin1 -> pin2 = 113 ohms
pin1 -> pin3 = 202 ohms
So this let me think that this variable resistor is 200 ohms...
Old 24th November 2019, 06:51 PM   #12
Mark Tillotson is offline Mark Tillotson
A schematic found for Mimesis 3 suggests a 220 ohm offset adjust VR, no bias adjust AFAICT.
Old 24th November 2019, 09:08 PM   #13
Onemangang is offline Onemangang  Denmark
Hi
Mark is correct. There are build threads for this good old amplifier here on diyaudio.
That also shows a 200 ohm'ish trim for offset adjustment.
Old 24th November 2019, 11:36 PM   #14
forr is offline forr  France
forr's Avatar
I have this schematics in my collection. The file name refers to Goldmund Mimesis 3.
Old 29th November 2019, 04:43 PM   #15
On the schematic posted by forr just after your reply , the variable resistor is 200 ohms, not 220 ohms.
I have bought and received 200 ohms variable resistors and when I have time to desolder the original ones, I will measure them (to tune the new ones to the same value than the original): I hope that I can use the 200ohms resistors that I have received !??
Old 1st December 2019, 05:50 AM   #16
trimmers are usually 10/20/50 scale, not E12, but people often assume its 10/22/47 scale - for almost any use of a trimmer the value is not crucial, since it can be varied or is used as a divider - substitute 220 for 200 or vice versa - remember tolerances can be +/-20% anyway.
What is the value of this variable resistor ?Hide this!Advertise here!
Variable Resistor values Karl vd Berg Parts 5 10th October 2013 07:14 PM
Resistor Variable, wirewound melpayumo Parts 2 16th April 2012 11:34 AM
Replacement for 200 Ohm variable resistor? maurycy Parts 5 8th April 2012 02:22 AM
variable resistor? studiostevus Digital Line Level 0 11th December 2010 09:28 AM
variable resistor akis Solid State 23 15th May 2010 07:44 PM
Copyright ©1999-2019 diyAudio
