Hi all,
I found, in second hand shop, a nice metal power strip. This is a power strip from "Scinetific Atlanta" Antenna Measuring System rack, model 2080.
It's okay, but I don't have male power plugs with horizontally oriented pins for L and N ? I also didn't notice them on the internet either.
What is this, some old models of power connectors, something for export only or ....
Some info is welcome, thanks
I found this on the internet:
15A Industrial Grade Angle Straight Blade Plug, Black/White; NEMA Configuration: 6-15P
Oddly - you would cover up both plugs with one device??? I would just change them to a standard IEC 10-15A plug for you area.
HUBBELL WIRING DEVICE-KELLEMS 15A Industrial Grade Angle Straight Blade Plug, Black'/'White';' NEMA Configuration':' 6-15P - 5Z879'|'HBL5666CA - Grainger
Changing to plugs in my area requires a lot of mechanical work on holes in power strip.
I think I'll decide on this:
Hubbell HBL8666V Valise Plug, Hospital Grade, 15 amp, 250V, 6-15P, White: Amazon.com: Industrial & Scientific
Thanks once again.
Thanks once again.
I'll try. Anyway whatever I do, will be better than the Chinese and some other plastic power strips offered in shops.
Totally agree! Good luck, have fun and hope it works perfectly. True DIY project - I like it!
Those look like regular outlets - the same kind you use in a regular wall socket. They just happen to be the 240V variety. Take the back off the power strip and see for yourself. Many industrial power strips are built this way. Rather than put the wrong plugs on your equipment, just install regular 120V outputs in the strip. Decent quality side-wired units with the screw terminals don’t have to cost a fortune - probably less than buying a bunch of 240V plugs. Which could ultimately get plugged into the wrong socket some day - and poof there goes your amp.
Oddly enough, the mains voltage in the eastern hemisphere is 220-250; The part of the world electrified by Siemens instead of Westinghouse. Bosnia Herzogovina where the OP is posting from is in the Eastern Hemisphere. Thus 250 v rated plugs would at least match the mains voltage, if not any equipment bought there.Those look like regular outlets - the same kind you use in a regular wall socket. They just happen to be the 240V variety. Take the back off the power strip and see for yourself. Many industrial power strips are built this way. Rather than put the wrong plugs on your equipment, just install regular 120V outputs in the strip. .
In continental Europe (230V +/- 5% mains V), all schuko power plugs and wall outlets for home use are stamped "250V, 16A".
As far as I can see, HBL8666V is labeled "250V, 15A". I opened my metal strip and on the back of the outlet is 250V, 15A label.
So I don't see any problem here.
Those sockets look rather like the ones we used to find distributing power inside the racks occupied by Digital Equipment PDP-11s etc. I assume they are used for internal power distribution in other equipment. Not really intended for powering 'portable' devices - for that you need to use whatever is legal in your country.
- Design & Build
- Parts
- Power plug
