Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Power plug
Power plug
Old 9th November 2019, 07:36 AM   #11
indianajo is online now indianajo  United States
indianajo's Avatar
Originally Posted by wg_ski View Post
Those look like regular outlets - the same kind you use in a regular wall socket. They just happen to be the 240V variety. Take the back off the power strip and see for yourself. Many industrial power strips are built this way. Rather than put the wrong plugs on your equipment, just install regular 120V outputs in the strip. .
Oddly enough, the mains voltage in the eastern hemisphere is 220-250; The part of the world electrified by Siemens instead of Westinghouse. Bosnia Herzogovina where the OP is posting from is in the Eastern Hemisphere. Thus 250 v rated plugs would at least match the mains voltage, if not any equipment bought there.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 9th November 2019, 10:59 AM   #12
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
In continental Europe (230V +/- 5% mains V), all schuko power plugs and wall outlets for home use are stamped "250V, 16A".
As far as I can see, HBL8666V is labeled "250V, 15A". I opened my metal strip and on the back of the outlet is 250V, 15A label.
So I don't see any problem here.
Old 9th November 2019, 12:09 PM   #13
DF96 is offline DF96  England
Those sockets look rather like the ones we used to find distributing power inside the racks occupied by Digital Equipment PDP-11s etc. I assume they are used for internal power distribution in other equipment. Not really intended for powering 'portable' devices - for that you need to use whatever is legal in your country.
Old 9th November 2019, 12:22 PM   #14
RajkoM's Avatar
I agree
Power plugHide this!Advertise here!
Where can I get the green power plug for my MiniDSP? djn miniDSP 3 27th October 2019 01:50 AM
bbc xlr canon power plug puremilk Parts 0 22nd September 2012 03:53 PM
chip burn-out when plug-in or plug-out DVD signal lines xujing79 Class D 3 3rd August 2010 06:07 AM
Help wiring power to 3 channel amp with one plug chevy2410 Chip Amps 57 30th May 2007 07:28 PM
Copyright ©1999-2019 diyAudio
