Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Fake or Real Fujitsu Part?
Old 20th October 2019, 07:19 AM   #1
SyncTronX is offline SyncTronX  United States
SyncTronX's Avatar
Default Fake or Real Fujitsu Part?
So I was wondering if any of you have come across some of these parts:
Fujitsu: 2sc2526
The parts I have show to be germanium????
On my Atlas DCA55 tester? WTF Over?
Anyone test any of these?
The actual reading from the DCA55 follow:
1) Hfe = 43 Vbe=0.54V DiodeCheck BC= .489 BE= .497
2) Hfe = 40 Vbe=0.54V DiodeCheck BC= .494 BE= .501
Tested the known good silicon device in the amp:
DiodeCheck BC= .570 BE= .573
Are these "NEW" Fujitsu ring emitters that good that the
PN junction is that low?
I've got New close complimentary Toshiba silicons,
1) BC= .570 BE= .570
2) BC= .558 BE+ .562
Tested the known good device in the amp:
BC=.545 BE=.551
Anyone else Test any of these?
-- Sync
Old 20th October 2019, 07:27 AM   #2
SyncTronX's Avatar
After reading the sticky...
I'll try to measure capacitance of the devices
and compare to known ones in the amp.
No sure how those will measure up and they are too much a pain to remove.
So stay tuned.
-- Sync
Old 20th October 2019, 07:28 AM   #3
ubergeeknz is offline ubergeeknz  New Zealand
Perhaps detecting as Germanium due to the vbe below 0.6v?
Old 20th October 2019, 07:55 AM   #4
dotneck335 is offline dotneck335  United States
"Fake or Real Fujitsu Part?"
Easy Test:
A) Did you buy it off eBay? FAKE
B) Did you buy it from Mouser/DigiKey? REAL
Old 20th October 2019, 09:52 PM   #5
SyncTronX's Avatar
dotneck335, not necessarily.
Uber, I'm not sure if that is the reason.
But, when I diode check BC to BE,
it reads, below .5V or near .5v.
Yes, Vbe below .5 or there abouts when it
we know its .7V across the PN junction.
Slightly less, .65 or high .57 ect.
I'd like to see if anyone has measured their
devices and compare.
-- Sync
Old 21st October 2019, 04:37 PM   #6
Mark Tillotson is offline Mark Tillotson
I think its more like:
eBay: all bets are off (real / real NOS / recycled / fake / non-functional are all possible)
Mouser/Farnell/digikey/etc: real
Anyway the low Vbe is because they are high current transistors and the tester doesn't know this. Vbe depends on
current density, not total device current.
Old 6th November 2019, 02:25 PM   #7
JeffYoung is online now JeffYoung  Ireland
JeffYoung's Avatar
Default Fake or real 2SK2013?
I'm trying to determine if some 2SK2013s I have are genuine or not. The case looks good (although the placement of the 'Y' grade marking is suspect: I think it's usually under the '2').
Fake or Real Fujitsu Part?-2sk2013-jpg
(Pics of other real & fake 2SK2013s can be found here: F5 with 2SK2013/2SJ313. )
I did some manual curve tracing with a couple of bench supplies. This is ID over VGS, with VDS fixed at 10V:
Fake or Real Fujitsu Part?-2sk2013_curve-jpg
While the curve looks about right, note that it's offset to the right by about 1.8V. I know the curve in the datasheet is only representative, but would there be that much variation in VGS?
Thanks,
Jeff.
Old 6th November 2019, 02:33 PM   #8
JeffYoung's Avatar
Ooops, meant to start a new thread.
Mods, feel free to move this if you think it worthwhile.
Jeff.
Old 8th November 2019, 04:25 AM   #9
SyncTronX's Avatar
Jeff,
No Need, it's all about fake parts.
But it would be nice if some other folks
would post what they measured.
It goes into the collective IQ of the DIY Brain.
-- Sync
Fake or Real Fujitsu Part?Hide this!Advertise here!
Real or fake? pdul Parts 6 17th January 2014 07:16 PM
Real or fake? SoNic_real_one Digital Line Level 38 4th March 2012 02:08 AM
fake or real ? mgm2000ro Class D 6 14th December 2008 08:03 PM
Fake or Real? Elso Kwak Parts 20 28th May 2005 09:32 PM
Copyright ©1999-2019 diyAudio
