Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Silly? question about Triad split bobbin transformer
Old 27th September 2019, 09:44 PM   #11
mchambin is offline mchambin  France
The data sheet tells wiring in parallel or wiring in series.
It doesn't tell leave some winding unused.
I see no advantage to do so. And the datasheet tells to not use them independently.
I would follow the datasheet.
Primaries in // for 110V mains, in series for 230V mains.
Secondaries in // for 5 V, in series for 10V ( with center tap 5V 0V -5V )
Silly ? YES, the datasheet is perfectly clear.
Transistor junction temperature is not transistor case temperature.
Old 27th September 2019, 10:24 PM   #12
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
Like i have written before i was expecting a higher voltage by creating a 5V that can supply 6A with a load of only 2A.
But problem is solved.
greetings, Eduard
Old 3rd December 2019, 03:55 AM   #13
gorgon53 is offline gorgon53  Finland
I guess it is a core type transformer and therefore both windings must be used.
Old 3rd December 2019, 10:48 AM   #14
mandu is offline mandu  Singapore
You ignore the data sheet. It only show the connection possibilities from the terminals. Connect the primary as per data sheet. Series or parallel. This is must. You can have the secondary in series or parallel or use only one or use each of the two secondary windings to different application. No harm. Just do not exceed the current rating of that winding. Regards.
Old 3rd December 2019, 11:06 AM   #15
wg_ski is offline wg_ski  United States
Do not exceed the voltage rating either, which implicitly is the end to end voltage of one of the secondaries. Do not get tempted, for instance, to power the heater of the rectifier tube off one and a rectifier and regulator for a DC heater for output or line stage tubes off the other. That puts B+ between adjacent turns and will result in a fireball, eventually. You could power two separate low voltage circuits off of it, provided both never got far above ground and that high isolation (including noise) was not required. The manufacturer still makes no guarantee the two circuits will remain isolated, and if it concerned safety in any way it would not get certification.
Silly? question about Triad split bobbin transformerHide this!Advertise here!
Wind choke on split bobbin Elerion Power Supplies 6 12th February 2018 08:45 PM
FS: EI core split bobbin power transformers DIYspaceW Swap Meet 5 24th November 2016 10:07 PM
R-Core or split bobbin or torroid multi 9V transformer wanted limono Swap Meet 0 6th August 2015 12:10 AM
Silly transformer question sparkydave Tubes / Valves 10 13th February 2013 01:22 AM
Split bobbin tranny only 83% efficient - is that normal? tonyptony Power Supplies 0 28th April 2006 02:13 AM
Copyright ©1999-2019 diyAudio
