Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
RCA to 3.5mm jack
RCA to 3.5mm jack
Old 9th September 2019, 02:08 PM   #1
DenDog is offline DenDog  Netherlands
Default RCA to 3.5mm jack
Quick question:
Is it a dumb thing to assume you can just use a converter cable between RCA jack (phono connector)
Old 9th September 2019, 02:17 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The centre of the phono or RCA jack goes to the tip of the jack plug, (right hand channel) and if stereo, the tip of the other phono plug goes to the ring of the jack plug.
The screens are connected together on the ground connection or sleeve of the 3.5mm jack plug.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 9th September 2019, 02:53 PM   #3
MarsBravo is offline MarsBravo  Netherlands
MarsBravo's Avatar
Tip - ring - sleeve = left signal - right signal - common ground
Y/Yo=(1-X/Xo)exp2 <> Y/Yo=(e)exp(X/Xo){Xo=kT/q}
Old 10th September 2019, 01:07 AM   #4
chrisng is offline chrisng  United States
If 4pole its not standardized, use a meter for continuity check!
Old 10th September 2019, 01:22 AM   #5
kodabmx is offline kodabmx  Canada
Spreading triode love.
RCA to 3.5mm jack
And they make cables...
AmazonBasics 3.5mm to 2-Male RCA Adapter Audio Stereo Cable - 4 Feet: Amazon.ca: Electronics
RCA to 3.5mm jackHide this!Advertise here!
Banana plug jack or RCA jack chassis mounted Hextejas Construction Tips 6 28th September 2018 08:56 PM
jack/jack on/off switch? imuntz Parts 0 5th November 2013 02:58 PM
how do i make a ATX cable to jack in/jack out pallebrus Construction Tips 0 11th December 2011 07:48 PM
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
making dual mono jack from single mono jack dubmunkey Analog Line Level 2 12th October 2006 02:16 PM
Copyright ©1999-2019 diyAudio
