Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
4066 operation
4066 operation
Old 23rd August 2019, 06:01 AM   #1
audiostrat is offline audiostrat  Greece
audiostrat's Avatar
Default 4066 operation
Hello,
I am posting to ask a simple question about the common analog switch 4066.
Can the power supply (and the control signals) to this IC be completely isolated from the analog path that will be injected into the switch I/O? No ground connection between them. In other words, can it be used as a "relay" where the "coil" circuit (IC power supply) has nothing to do with the switching path.
Old 23rd August 2019, 06:10 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
No. If you want isolation between the control side and the analog signal path then you could use something like this : TLP592A(F) Toshiba | Mouser
Its more expensive and slower to switch, but has a much lower on-resistance.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 23rd August 2019, 10:03 AM   #3
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
And the signal voltages mustn't exceed the voltages at both the 4066's negative and positive supply pins.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 24th August 2019, 11:10 AM   #4
Mark Tillotson is offline Mark Tillotson
These analog switch chips use CMOS transmission gates, which are not isolated in any way.
CMOS chips have anti-static protection diodes on the pins, so the voltages on any pin must stay without the supply rails at all times.
There are many modern analog switch chips with far superior performance to the original CD40xx series versions, but they all use transmission gates.
Old 24th August 2019, 08:53 PM   #5
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Care needs to be taken with voltages in and out of IC's.
I did a USB project and accidentally drove an output 5 volts into a another IC powered off 3v3. The PC went nuts and said it was closing down to stop damage to it !
PCBCAD51 download or CDROM 2019 version out now https://www.murtonpikesystems.co.uk
Old 24th August 2019, 09:10 PM   #6
MarcelvdG is offline MarcelvdG  Netherlands
But compared to a 4066, it has a much larger off-state capacitance, so depending on the circuit, some treble may leak through when it is off. In any case, there are other optocouplers with MOSFET output, the trick is to find the best compromise between on resistance and off capacitance for the application.
Old 24th August 2019, 09:36 PM   #7
Again depending on the application, the main risk is probably latch-up. Most ICs (including the 4066) are full of parasitic thyristors between supply and ground. An input or output voltage above the positive supply or below the negative supply can trigger these thyristors. Nowadays ICs are usually designed not to trigger as long as the input or output current stays below 100 mA, but I don't know what the limit used to be when the 4066 was designed.
If a parasitic thyristor should get triggered, the IC will burn out unless the supply has a low current limit and no big decoupling capacitors. You often see 4000-series electronic switches being supplied by resistors and Zener diodes, that's probably a good idea if there is any risk of the input going above the positive or below the negative supply.
Old 24th August 2019, 11:40 PM   #8
The 4066 has been around for a very long time.
We used them in 1981 in a Prestel adaptor (forerunner to the internet)
The 4016 was a similar device.
Old 25th August 2019, 03:24 AM   #9
davidsrsb is offline davidsrsb  Malaysia
There is a reason that we still use signal switches and relays in the 21st Century
Old 25th August 2019, 03:34 AM   #10
synonymous is offline synonymous  United States
Send a message via MSN to synonymous
If you are looking to mute a signal, consider grounding rather than an analog through switch.
4066 operationHide this!Advertise here!
General opinion of 4066 audio switching IC? Artie Parts 2 6th May 2010 01:21 AM
Amp switching with 4093/4066. How to add indicator LEDs? soma_hero Tubes / Valves 3 20th January 2010 01:57 AM
CFB and A2 operation hemgjord Tubes / Valves 2 9th September 2008 10:42 PM
operation below fs zenmasterbrian Subwoofers 60 21st October 2006 11:40 PM
Datasheet for IRF 95-4066 sayang001 Parts 0 20th April 2004 09:31 PM
Copyright ©1999-2019 diyAudio
