Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How can a metal film resistor increase in value?
Old 21st August 2019, 09:57 PM   #11
Mark Tillotson is offline Mark Tillotson
Originally Posted by ColinA123 View Post
One possibility, your meter is not accurate at such low R value.
A four-terminal (aka Kelvin) measurement is needed for low-value resistors. I use a bench supply set to 1.0A to drive the resistor and measure the voltage across the resistor with a multimeter, simple and easy for sub-ohm resistors. For range 1 to 10 ohms 0.1A is a safer current to use. Probe the resistor right on its terminals/leads, avoiding the cable resistance.
Old 22nd August 2019, 01:59 AM   #12
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by Beemer2 View Post
Dan, You gave me new knowledge......
Glad to help you Ian.
That quote is a little ambiguous, except for Carbon Composition tubular resistors are are an insulating ceramic rod with coating (matrix ?) of conductive material.
Be sure to use a bulb tester.
Dan.
How can a metal film resistor increase in value?Hide this!Advertise here!
Which source resistor to use MOR or Wirewound or Metal film? rhythmsandy Solid State 1 16th February 2015 01:01 AM
About metal film resistor in a tube tuner yoplaboum Tubes / Valves 20 24th September 2013 12:04 AM
1000 Piece Resistor Kit 1% metal film 0.6W all useful values $33 each incl shipping len_scanlan Vendor's Bazaar 55 12th November 2010 07:57 PM
help, metal film resistor and heatsink? eldarvanyar Construction Tips 6 11th May 2010 07:20 AM
Resistor types ??? (carbon or metal film) Apogee Parts 30 10th March 2010 06:59 PM
Copyright ©1999-2019 diyAudio
