Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
How to identify fake JFETs?
Old 10th June 2019, 12:06 PM   #31
EUVL is offline EUVL  Europe
> 'Stormsonic' in post 19 showed that measurements of fake units can actually be pretty close to genuine ones.
How does he know they are fake ?
Has he other meassurements such as noise, capacitance, ..... to prove so ?
Signing off,
Patrick
xen-audio.com
Old 11th June 2019, 02:40 PM   #32
davidsrsb is offline davidsrsb  Malaysia
It is perfectly normal with the big manufacturers for the same die to be packaged and tested at several plants (often third party), often using different leadframes and moldings.
They are all genuine parts.
Old 11th June 2019, 05:37 PM   #33
ej25awd is online now ej25awd  Canada
formally hitachi_nut
Not perfectly normal for the Toshiba 2SK170 which is the original body of this thread.
Give us your documentation that support Toshiba 2SK170 dies are assembled by a third party who intentionally use a smaller epoxy package from what was specified on the 2SK170 datasheet.
Old 12th June 2019, 01:20 AM   #34
Has Toshiba told you that they only use one package style?
I don't believe that in the posts above that Marantz would have bought fakes and the HDAM module would not work with the typical die used by the fakers.
There are few third party test and package plants here in Malaysia, all producing finished parts for some of the semiconductor majors in a totally official and legit way. I am sure that there are others around SE Asia.
Old 12th June 2019, 01:53 AM   #35
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
While I 100% believe the Marantz parts are genuine, it's been pretty well documented through measurements that many of the discontinued Toshiba jfets offered now are not genuine.
Tim
Old 12th June 2019, 03:21 AM   #36
davidsrb,
Give me a Toshiba 2SK170 datasheet/ECN/ECO that supports your pure speculation of the existence of another 2SK170 TO-92 packaging dimensions that matches the OP's counterfeit 2SK170 measured dimensions. If you don't
have any just STOP!
You should be aware that reckless and unfounded statements just add more confusion to members which could end up as potential preys for counterfeiters.
Old 12th June 2019, 09:08 AM   #37
That almost everything for sale now on auction sites is fake we are sure of, they don't even measure close
Even the Linear Systems LSK170 is being faked
Old 12th June 2019, 09:21 AM   #38
kamis is offline kamis  Serbia
Show me an original Toshiba J-Fet ( measured) which has no 2mm center line on the top.
Old 12th June 2019, 09:29 AM   #39
andyr is offline andyr  Australia
So now that genuine thru-hole 2SK170s are no longer available - can anyone tell me the code for the SM equivalent?
Or the SM equivalent of the 2SK369?
Thanks,
Andy
Old 12th June 2019, 10:42 AM   #40
fredbloggstwo is offline fredbloggstwo  United Kingdom
Hi there,
if you are going to test a lot of transistors for fakes or otherwise, can I suggest you get yourself a Peak DCA 75 tester.
As well as testing the obvious parameters, it will plot the characteristics on a computer screen, which you can then chack directly against the manufactures' data sheet as a first level of confidence.
Brilliant investment for about 100.
Mike
How to identify fake JFETs?Hide this!Advertise here!
How to identify Fake Transistors? Jrp27 Parts 10 27th August 2018 03:14 AM
2SA1215 2SC2921, identify genuine and fake Sunmansli Solid State 10 15th May 2018 03:51 PM
How to identify a fake Toshiba transistor? Audio Maniac Parts 1 7th July 2012 08:06 PM
Is there ANY way to identify a fake LM3886 before buying one ??? MrAdel1984 Chip Amps 9 4th April 2012 07:55 PM
how to identify fake transistors Wagener Solid State 4 6th May 2004 01:46 PM
Copyright ©1999-2019 diyAudio
