NPN, 1W, 160V, 50mA, 120MHz. You could try mpsa42, mje340, or 2n5550. If the original failed from heat then go with mje340. If it doesn't get hot, then 2n5550. Schematics I can find run 2sc1941 as the VAS at about 6.5mA and 280mW (+-43V) , so any of these will work, but the power is a bit tight so I would use mje340. Note that with +/-43V, you don't need 160V. A 100V transistor would be fine. But if the amp spend any time at the +ve rail, you have 86VDC *6.5mA = 560mW, very close to the 2n5550 limit of 625mW. In any case, be careful with the pin-out.
ksc3503E or F, 2sc3423...2sc2911
VAS transistors for sale 2SA1360Y/2SC3423Y,2SA1209S/2SC2911S and KSA1381E/KSC3503E
