Neutrik make some nice connectors; NF2D-B4 | Neutrik Black Panel Mount RCA Socket with Gold over Nickel Plated Contacts, 16A | RS Components
Panel Cut Out Diameter: 10mm
Overall length: 29.5mm
Suitable for max. 3.8mm Panel
CMC 816-WU Female RCA Jack Terminal HIFI AUDIO AMP Speaker Connector DIY Gold*10 | eBay
Panel Cut Out Diameter: 11-12mm
Overall length: 32mm
Suitable for max. 5mm Panel
RCA Female Chassis Panel Mount Jack Socket Connector Phono Copper Jack Amp HiFi | eBay
It is, ten mm is .393, and 3/8 is .375.
As long as it isn’t shorted to the case, and looking closer it does look like the stepped washer actually matches the dimension of the actual socket, which is 3/8”.
Sorry for the quick evaluation before...
I will be getting a set as well.
I think I have a couple of sets of similar RCA sockets. They are 8mm and too small for the holes in my enclosure even with the attached washers.
- Design & Build
- Parts
- RCA sockets for 10mm holes?
