Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Transformer Specs
Transformer Specs
Old 22nd February 2019, 11:15 AM   #1
sbusso is offline sbusso
Default Transformer Specs
I have fried the PSU of an Aphex Voice Channel 230. Then I have reversed engineered the PCB and got almost everything except the transformer. The old transformer with no description or name, was sent to a shop to make a new one but it didnt work and now I have only the schematic left. Is it possible to reverse the spec of the transformer from the schematic (pdf attached) ? Le load is quite low and the power rating of the channel is 15W.
Thank you.
Old 22nd February 2019, 11:39 AM   #2
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I have been repairing SMPSUs for years and never come across a faulty transformer other than physical damage.
The mains fuse will save it.
There are a number of components the fault could be and without working on it, I would only guess at, Power FET, driver/osc chip, R2 will undoubtedly be damaged as will the surrounding components.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 22nd February 2019, 11:45 AM   #3
You are right, the transformer was not faulty, a diode after the transformer did burn, I could not get SMPSU working again so I went on a harder way to rebuild it from what I had, but I was not able to reuse the transformer and tried to get a new one, unsuccessfully.
Transformer SpecsHide this!Advertise here!
Transformer specs? TroelsG Power Supplies 40 21st July 2013 08:53 AM
transformer specs magelord04 Power Supplies 3 1st August 2007 04:19 PM
Transformer Specs Gunny Instruments and Amps 1 17th January 2007 05:52 AM
getting the specs on a transformer pango Tubes / Valves 4 18th December 2006 01:39 PM
looking for transformer with the following specs? matthew2456 Tubes / Valves 4 22nd August 2006 09:58 PM
Copyright ©1999-2019 diyAudio
