The Kemet looks fine if you don't mind paying over $4 a pop, compared to the 1206 version which will set you back $0.85 for ten (on Mouser). Unreasonably affordable for NP0 caps, I had to read the datasheet through to check its not a mistake!
Apart from the diminished size which means less noise pick-up, I can't think of any advantages of NP0 over metallized PP.
Hi, they don't make larger values then 100nF for 1206 NP0?
Wima metallized polypropylene is still the best bang for the buck:
MKP4D034704D00KSSD
72¢; 18 L x 7 W x 14 H mm; 100v; 10%
MKP4D034704D00KSSD
