Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Distortion in capacitors
Old 11th February 2019, 08:43 PM   #1
nauta is offline nauta  Canada
Default Distortion in capacitors
Hi
Most hobbyists and techs know about the great article written by Richard Marsh and Walt Jung from back in the 1980s or so, and the update made by Cyril Batement a decade ago, but has anyone tested all the new caps?
We know polypropylene is essentially zero THD, and so is polystyrene. PP is easy to get but PS seems to be rare and only in tiny values.
Polyester aka mylar adds odd-order THD.
Polycarbonate seems to have nearly disappeared and is maybe in between polyester and polypropylene.
Mica is okay.
Ceramic can be okay below quite low pFs and only if N0P or C0G.
What about polyethylene-napthlate or -terapthlate?
polymer caps?
polyphenylene sulfide / sulphide?
silicon dioxide / nitride?
aluminium organic polymer? (probably as bad as standard electrolytics?)
It seems there are a lot more dielectrics to choose from - or not to choose from
Old 12th February 2019, 12:19 AM   #2
alexberg is offline alexberg
alexberg's Avatar
There is/was a paper by NSC Bob Pease discussing absorption and other particularities in different dielectrics.
Basically Teflon, PP and NP0 ceramic are the good ones. It all depends on voltage across the capacitors.
In simpler terms you may check dielectric properties.
Old 12th February 2019, 12:22 AM   #3
alexberg's Avatar
Bob Pease on Audio Capacitors
Old 12th February 2019, 12:23 AM   #4
alexberg's Avatar
Passives Aren’t Really So Passive (Part 1): Capacitors - Application Note - Maxim
Old 12th February 2019, 12:24 AM   #5
alexberg's Avatar
https://www.eetimes.com/document.asp?doc_id=1278898.
Old 12th February 2019, 12:42 AM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Linear Audio, I think it was Volume 12, had a great article using a quadrature rig to measure THD%. Even more precise than Cyril's articles of decades ago.
Old 13th February 2019, 03:36 AM   #7
I was actually hoping for new THD tests of these other dielectrics. I guess there are none?
Old 13th February 2019, 05:30 AM   #8
MarcelvdG is offline MarcelvdG  Netherlands
Polyethyleneterephtalate = polyester
Covered in Cyril Bateman's original series: better than polyester, but not quite as good as polystyrene.
Silicon dioxide and silicon nitride are used for the highest performance capacitors on integrated circuits, so maybe you can find something about them in the Journal of Solid-State Circuits. By the way, the dielectric of a Leyden jar also consists mainly of silicon dioxide.
Old 13th February 2019, 05:53 AM   #9
jazbo8 is offline jazbo8
jazbo8's Avatar
Thread moved to Parts.
Old 14th February 2019, 01:07 AM   #10
Hi Marcelvdg: That is good info, thanks!
Hi jazbo8: I didn't see a component forum so put it in SS since that is where cap distortion will reveal itself best - or worst?
Distortion in capacitorsHide this!Advertise here!
Separate driver distortion vs. whole speaker distortion mtoc Multi-Way 2 13th July 2016 06:49 PM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 01:38 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 03:54 PM
Distortion and Base Capacitors in Differential BJT Pairs subwo1 Solid State 1 21st September 2003 08:39 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
Copyright ©1999-2019 diyAudio
