Why would you?I don't know how to pull this board off the plate. I tried cutting the black adhesive material with a hobby knife.
Leave the black goo alone, it´s there for good reason: vibration damping.
You barely show the important part, the MosFets which are bolted to the panel heat sink and using white thermal grease and mica.
As I see it, the perpendicular mounted PCB allows you access on both sides: parts and solder, so no need to dismount it.
