Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Parts and components salvaging
Old 8th January 2019, 04:10 PM   #11
kodabmx is offline kodabmx  Canada
Use a heat gun instead (or a rework station). No need for flames.
Old 9th January 2019, 05:53 PM   #12
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Flames heat a larger area quicker. Anyone with half a brain will do this outside...
Old 9th January 2019, 06:36 PM   #13
fredbloggstwo is offline fredbloggstwo  United Kingdom
I've ofter throught it would be a good thread to have showing photos of recycled parts used to build amps, power supplies etc.
There is a guy on Ebay UK who sells empty equipment cases - including some military with the guts taken out. I got a few HP pulse generator cases from him and they were great for housing power supplies for my Class A Power Amp. They are built like a tank and also had some extra goodies like power switches etc.
Cheers
Mike
Old 9th January 2019, 06:46 PM   #14
ferret is offline ferret  South Africa
ferret's Avatar
Default Ebay link?
Hi Mike,
Do you maybe have a link to this ebay seller, please? Many thanks for the goodies, now to make time after work to get down to things. Though first busy testing & "profiling" BJTs small, medium and large with my new DCA55. This is a process that needs lots of space and containers.
On track though - I have managed to get hold of quite a number of not economically repairable UPSs at work. Lots of inductors, but most especially heatsinks to be had. A few componnts may be salvageable, but most of these have blown FETs and/or caps. Most are 8 to 10 years old so the electonics is generally too olde to be harvested. I have never thought of reusing the cases though. Will do so in future though, as these are normally soildly built blighters.
Kevin
Ferret. - Gaya rules
Old 9th January 2019, 07:43 PM   #15
Hi Kevin,
the ebay seller is mjtronix but he is on ebay UK and I am not sure if he ships internationally, but worth a try.
I eventually bought 3 case from him as I got a good deal and he was a good guy to work with.
I have attached some photos showing the cases:
the first is the raw case with the inner rails etc removed
The second is the Class A power supply installed (Transfromer, mains DC offset remover, softstart circuit and smoothing board)
The third is the final result looking cool. - sorry about the crappy photo
Best regards
Mike
Old 10th January 2019, 07:37 PM   #16
almo is offline almo  Canada
Default Test equipment photos
Thank you for the replies. Here is a few pictures. I just need to learn which parts/Components to spend time on and which ones go in the bin. Bourns, mills, dale, switchcraft, helitrim, are some notable brands. I am currently digging for heatsinks and power supplies for my upcoming ACA project-anything I can do to mitigate the exchange/duties and lower my cost.
Thank you, Almo
Old 12th January 2019, 08:16 PM   #17
phase is offline phase  United States
Cheers
Mike
I have though about this, especially for certain areas of the world that donít have access to parts through the same channels as most of us.
I know whenever a device is put out to pasture in our house, it goes through the shop first, and whatever can be quickly removed is saved in a bin for experiments or use even.
Old 13th January 2019, 01:24 PM   #18
Another hint for re-using stuff is to look on Ebay using the search for "Amp for spares or repair" or similar, as you can get very good chassis and components that way.
Also, look for items located near you that require personal pick up. They will usually have less bids and thus be significantly cheaper.
Cheers
Mike
Parts and components salvagingHide this!Advertise here!
Questions about console parts salvaging Childeric Tubes / Valves 23 16th September 2014 11:34 PM
F5 components, parts you use tinitus Pass Labs 107 19th June 2012 09:18 PM
Salvaging parts from vintage receiver for DIY hd220 Solid State 5 17th February 2010 06:40 PM
where to buy parts and components? brownj24 Everything Else 6 21st June 2008 10:04 AM
Salvaging parts from dead computers, worth? MrDodo Parts 12 8th October 2005 04:15 PM
Copyright ©1999-2019 diyAudio
