Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Polymer caps (SEPC)  Vs Silmic II for coupling
Old 16th October 2018, 05:20 PM   #1
legarem is offline legarem  Canada
legarem's Avatar
Default Polymer caps (SEPC) Vs Silmic II for coupling
Hi
I have to change the coupling caps in a preamp. There's not too much place to use film caps so I would like to upgrade the tantalums and electrolytic caps in the signal. Silmic II seems to be one of the best electrolytic caps to use in the signal path. Someone mentionned me that organic polymer (SEPC) caps should be better. I never tried them so what do you think about them for signal coupling ?
Old 16th October 2018, 06:40 PM   #2
pdul is offline pdul  Denmark
Organic polymer caps have a higher leak current. Just have that in mind when experimenting
Old 16th October 2018, 07:16 PM   #3
rayma is offline rayma  United States
Tube or transistor? What value and voltage?
Old 16th October 2018, 08:44 PM   #4
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Tubes with polymer caps? Perhaps in the heater circuit, but not likely as coupling.
Old 16th October 2018, 09:24 PM   #5
phase is offline phase  United States
I used to use polymer caps for digital decoupling, where they are not bad, now just main filtering for digital circuits.
They arenít really what youíd want for analog power let alone in the signal path.
Iíd look at the nichicon muse, with a small film bypass.
Old 17th October 2018, 05:04 AM   #6
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
For coupling or for bypass?
Knowing the circuit in question would likely yield you better answers.
Iíve used polymers in heater supplies for quite a while.
I havenít seen much of a credible / technical answer for why they wouldnít be superior to a regular Electrolytic across the board.
To my knowledge none of the more involved studies of caps utilized polymers, just regular electrolytics and bipolars.
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Polymer caps (SEPC)  Vs Silmic II for couplingHide this!Advertise here!
FS: 2200uF 6,3v Aluminum Organic Polymer Caps vdi_nenna Swap Meet 2 5th May 2017 01:01 PM
Elna SILMIC, FOR AUDIO, SILMIC II Alpha caps for sale cathodes Swap Meet 4 14th October 2016 02:55 PM
Nichicon Conductive Polymer Caps sewerwisp Parts 3 10th June 2009 02:19 PM
FS: Sanyo OSCON SP SEP SEPC Series Caps Orb Swap Meet 1 23rd September 2005 02:54 PM
Polymer Aluminum (AlO) Caps tiroth Parts 0 17th May 2002 02:45 PM
Copyright ©1999-2019 diyAudio
