Hello, I am just starting out on an F5 build, it is my first DIY project. I have a couple of questions that I appreciate some advice if anyone would kind enough to help.
i. For cable on the signal path I am thinking of a AWG22 multi-conductor, copper core, with tin plating and silicone insulation (high dielectric strength), would this cable choice be appropriate or would you advice a cable with a degree of shielding?
ii. On the PSU, is there a limit on max capacitance, that is, is too much capacitance capacity a problem providing the power requirements of the amp is met?
Thanks in advance.
Neil
Thanks in advance.
Neil
In time silicon insulation degrades as it is never a solid. In my experience, a fresh loom was manufactured for an amplifier board using similar silicon insulated cables. There was a tight 90 degree bend and after a few years the inner conductors started protruding through the insulator. If balanced digital signals, twisted pairs are preferred rather than screened balanced/unbalanced cables.
All that is required is enough capacitance to bring down the impedance of the supply to a level that stops ripple. Too much is a waste and shows a design with poor knowledge.
Generally speaking if using an LM78/9 type of regulator, 100uF is adequate on the output side for up to 1Amp. Any more and it causes problems within the regulator chip.
