It's an automotive, 10 pin connector, need 1 male and 1 female.
Maybe a Molex (could be either a standard or a custom part). You'd need an expensive
specific crimping tool also. Check aftermarket Corvette third party sources too.
My experience with Molex et al is that you buy the nylon housing, and the crimp pins separately.
Yes, all such parts are a la carte. An old Corvette means it's from an old American parts company.
In Europe there is a French Store called Norauto who sells those kind of things for every car. They have extensive catalogs with parts, but as it is an American car I don't know if they can help You. I'm sure there must be American or Canadian stores like this. That connector is similar to Toyota factory installed. In situations like this I cut the wires and put an ISO connector instead. You could also use some sort of electrical industrial connector for this.
Googling … just found this site.
http://www.autoharnesshouse.com/
Hi there.
I did a little research.
From the product description on Corvette Central, there is a hint.
(Assembled with original GM Delphi connectors)
From there I found that Mouser have the Delphi/Aptiv connector line.
I just dig in the catalogue, and they look identical to the Metri-Pack 150 series connectors.
PS. You must double check, I don't want you orders the wrong parts.
You would need the following parts (look the catalogue for parts Nbr.):
-1x male 10 positions unsealed connector
-10x male terminal (check wire size)
-1x male TPA (terminal position assurance)
-1x female 10 positions unsealed connector
-10x female terminal (check wire size)
-2x female TPA (terminal position assurance)
Optional:
-1x CPA (connector position assurance)
And the crimping tool.
https://www.mouser.ca/Connectors/Au...-1ehb5?Keyword=110893600&FS=True&Ntk=P_MarCom
http://ecat.aptiv.com/docs/default-...et150-pdf.pdf?Status=Master&sfvrsn=bf6f84d9_0
Optional:
