Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
RF Relays suitability for AF switching
Old 16th September 2018, 12:21 PM   #1
Kris0603 is offline Kris0603  Sweden
Default RF Relays suitability for AF switching
So, i had some relays kicking around for decades, they are Hi-G 2K series, DPDT with 26.5 and 12V coil voltage.
I don't build any RF stuff but i was thinking of using one as an input selector in an upcoming project. Anyone with experiences with these, suggestions for suitable drive circuits, anything? I want to use these for the point-to-point look.
Old 16th September 2018, 03:46 PM   #2
russc is offline russc  England
Relay contacts are either for high current (amps) and built to withstand arcing or low current (milliamps) and made so they don't tarnish & offer resistance to the small current.
Those look like high current relays.
Old 16th September 2018, 08:02 PM   #3
Thanks for the reply!
I think what's special about these are that they are designed and built to aerospace specs, so they withstand adverse conditions, better than standard grade, presumably.
Found a datasheet, seems they should be OK switching line level AF.
Old 17th September 2018, 08:54 PM   #4
Monte McGuire is offline Monte McGuire
As long as these relays are new or haven't been chewed up switching inductive loads, they should be excellent for low level audio switching. They're hermetically sealed, and have gold coated contacts, so they will have excellent low level performance.
The coils are pretty low impedance, 12V @ 160Ω and 26.5V @700Ω, so you might have to use a slightly beefy transistor to drive them, if you want to control them with a logic signal. They also have no clamping diode, so make sure to add that if you control them with a transistor. A simple NPN with emitter to ground and collector to one side of the coil, with the other side attached to 12V or 26.5V as appropriate would work, along with a reverse biased diode across the coil to clamp its switch-off inductive kickback. Add a resistor in series with the base to limit the logic drive current to the Vbe junction - that value will depend on how much drive your logic can provide.
Old 18th September 2018, 06:48 AM   #5
Sweet, that is exactly what i was after, many thanks Monte!
RF Relays suitability for AF switchingHide this!Advertise here!
Phono switching with relays. billshurv Analogue Source 68 28th February 2018 09:22 PM
Muse M20 EX2 TA2020 amp, relays switching on/off Marc G Class D 1 26th November 2017 08:10 PM
High Current relays for speaker switching? Zero Cool Everything Else 13 15th December 2006 11:52 PM
Relays for switching i2s or other 3-wire audio bus? mbcouple Digital Source 19 23rd July 2005 08:58 AM
BOSOZ source switching with SE relays Gabrielshorn Pass Labs 2 5th February 2004 08:07 AM
