Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Electrolytic Capacitors With Higher Stamped Value
Old 13th September 2018, 10:29 AM   #11
Michael 5of9 is offline Michael 5of9  United Kingdom
Michael 5of9's Avatar
Question Capstan Motor Bipolar “NP” electrolytic capacitor 15μf 16v redial
On a Philips cassette deck there is a Capstan Motor; with a bipolar type “NP” electrolytic capacitor 15μf 16v redial fitted.
Electrolytic Capacitors With Higher Stamped Value-capstan-motor-cap_6660-jpg
Electrolytic Capacitors With Higher Stamped Value-capstan-motor-cap-jpg
I was thinking about replacing this cap; however looking on eBay, finding a 15μf cap has proved to be a challenge
I haven’t remover and tested because it is heavily/well soldered and likely to cause damage to the cap
Kind Regards Michael
Heating & Electrical Engineer
Old 15th September 2018, 02:02 PM   #12
glennb is offline glennb  Australia
Go up to 22uF. Higher voltage rating would also be OK.
Glenn.
Old 22nd September 2018, 10:44 AM   #13
Post Becoming More Clearer
Thank you Glenn for that; could I kindly ask for your thoughts on this, the higher 22μf cap to gain more understanding, thanks?
A very good day to you all and thank you for your valuable comments, well appreciated; it has become clearer now.
Electrolytic Capacitors With Higher Stamped Value-electrolytic-capacitor-specs-jpg
Electrolytic Capacitors (cap) have a life span of around 1000 hrs; with this in mind, the higher readings are most likely acquired because of leakage from the old cap, as some suggests.
With this in mind; it would make sense to replace them all, whilst the job is in hand. Below you can see the new cap and it’s capacitance reading.
Old 22nd September 2018, 12:45 PM   #14
cliffforrest is offline cliffforrest  United Kingdom
"Electrolytic Capacitors (cap) have a life span of around 1000 hrs ..."
Please think about that! If true then all elkos would need replacing 3 or times a year in ALL of your electronic equipment!
Old 22nd September 2018, 01:21 PM   #15
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
In the old days, when manufacturing was not as refined as it is now, electrolytics were often value tolerance specified as "-50%/+100%". Although that 247uF is really something else.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 22nd September 2018, 04:11 PM   #16
I bought this new in the early 1980's; it's the first time around for renewing the elkos.
I replaced many elkos in an amplifier; which really improved the sound quality, about 4 years ago of the same age, this impressed me to continue and do the same in this unit.
Old 22nd September 2018, 04:32 PM   #17
? So why state that there is a lifespan of 1000 hours?
Where did you get that info from?
Old 22nd September 2018, 05:15 PM   #18
DF96 is offline DF96  England
If you look carefully it says 1000 hours at 85C. Run it cooler and it will last longer. Also, this is what the datasheet says; it is probably a minimum spec so most production caps will last longer than this. It is also probably a 'running' spec, so hours switched off don't count. Take this all together and you find that a cool electrolytic can last many years. 10, 20, 30 years are possible in a non-critical circuit position in domestic audio.
Old 22nd September 2018, 05:32 PM   #19
I am aware of that.
I was objecting to it being quoted as an unqualified truth that reinforces the attitude that "all caps, especially elcos, are the devils work and should be replaced wholesale. Everywhere."
Old 22nd September 2018, 05:41 PM   #20
Whoops! I didn't read all of the thread. Apologies.
I am having a "grumpy old man" day, partly because it is grey, raining and cold out.
Electrolytic Capacitors With Higher Stamped ValueHide this!Advertise here!
Best electrolytic capacitors Nelson Pass Parts 1263 15th July 2018 04:00 AM
Electrolytic Capacitors alibear Swap Meet 2 19th August 2017 04:44 PM
NOS electrolytic capacitors? redrooster Parts 11 22nd August 2016 11:50 PM
WTB 22000uf 100v or higher capacitors reddish75 Swap Meet 2 20th October 2014 09:02 PM
Higher value oil capacitors? rick57 Tubes / Valves 36 24th March 2006 07:48 PM
