Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
10k pot vs 100k pot
10k pot vs 100k pot
Old 29th July 2018, 01:28 PM   #1
edwtsui is offline edwtsui  Hong Kong
Default 10k pot vs 100k pot
From distortion perspective, is there any difference between 10k pot and 100k pot? What is the reason to use high resistance pot instead of using low resistance pot?
Old 29th July 2018, 01:42 PM   #2
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The 100kOhm pot has a rather high output impedance over much of the volume range. When the next stage has a low input impedance and a high capacitance ( can also be a long cable ) then the treble will be rolled of.
Old 29th July 2018, 01:45 PM   #3
When the pot is near the input stage and the input impedance is high ( Tube, Fet ) and Lw capacitance then the 100kOhm has the advantage that the stage before it does not get loaded much. Than can result in lower distortion when the driving stage is rather weak in clean current delivery.
Old 29th July 2018, 01:47 PM   #4
00940 is offline 00940  Belgium
00940's Avatar
If the driving source is very weak, the 100K might be an easier load for it.
On the other hand, the high output impedance of a 100k pot might create higher common mode distortions if the the input stage is a classical non inverting opamp.
All that is excessive is insignificant. Talleyrand
Old 30th July 2018, 03:09 AM   #5
That means, for high input impedance of input stage, use 100k instead of 10k. For low input impedance of input stage, use 10k instead of 100k???
Old 30th July 2018, 05:38 AM   #6
Diabolical Artificer is offline Diabolical Artificer  United Kingdom
Diabolical Artificer's Avatar
Your question was with respect to distortion, if you get your signal generator and connect it to first a 10k pot then a 100k pot, you won't see much difference in THD. Distortion is more a product of non-linear gain, so if your pot was the anode load for triode/common emitter gain stage, you would get more distortion with a 10k pot as the load line is steeper and as a result gain on the positive and negative going parts of the cycle will have a bigger difference, will be less linear and as a result have more THD.
But your not likely to use a pot as a load for the above example. Took me ages to get my head round impedance, it's counter intuitive. You can't really think about your pot in isolation, think of impedance's as a potential divider, like a voltage divider and they make more sense.
On the input side you want a high Z to drive into, a low Z IP will be harder to drive as it will need more current to drive it.
On the OP side, you want your circuit to have a low OP Z, it can drive following circuits easier without distortion.
If we knew what your circuit is, we may be better able to advise you. If your pot is the first thing a voltage source sees, a 100k is better than 10k, roughly speaking.
Andy.
Old 30th July 2018, 08:14 AM   #7
Hi Andy,
Thanks for your answer. I am going to place the pot to the input of my headphone amp. I have a 10k and 100k pot, don't know which one is better?
Class A headphone amplifier by Kevin Gilmore
Old 30th July 2018, 09:25 AM   #8
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
10k pot vs 100k pot
The newer Gilmore amps are normally designed for 10k pots (low-isn input impedance). This one is less picky because it has FET inputs, but 10k should still be the best choice.
DIY projects blog
Old 30th July 2018, 01:23 PM   #9
So, for pot connected to input stage, lower impedance is better???
Old 30th July 2018, 03:27 PM   #10
DF96 is offline DF96  England
R.I.P.
Meaningless question. It is very likely that they are of similar quality, so the question you should ask is: what is the appropriate pot value for my situation?
You can get a first approximation by taking the output impedance of the source and multiplying by the input impedance of the load, then take the square root. Double the answer. This assumes that each are equally likely to have a non-linear impedance. If the source has a more nonlinear output impedance then increase the pot value; if the load has a more nonlinear input impedance then reduce the pot value.
  Reply to this post
10k pot vs 100k potHide this!Advertise here!
$2.50 each 100 qty 100K log/100K anti-log potentiometers available mrbutterskin Swap Meet 1 6th February 2014 11:35 PM
WTB Noble 100K log merlin el mago Swap Meet 11 30th March 2013 02:10 PM
EL-34 and 100k pot podboy Tubes / Valves 1 26th June 2007 11:49 PM
50K vs 100K POT ss1 Parts 7 22nd July 2004 12:57 PM
50K or 100K pot? 2Bak Chip Amps 14 9th November 2003 02:25 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
