Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Audio note kaisei capacitors
Thread Tools
Old 21st November 2020, 06:20 PM   #71
phase is offline phase  United States
Iíve also found that just leaving something run continuously doesnít work as well either, and usually takes around three weeks, running around half the time.
Pretty crazy, but happens every time...
Old 21st November 2020, 07:11 PM   #72
cbdb is offline cbdb  Canada
No, totaly crazy.
Old 21st November 2020, 08:39 PM   #73
Klimon is offline Klimon  Belgium
I'll give it some more time
Meanwhile, 4 hours and some Belgian abbey beers later, things are sounding peachy.
Probably less so in the morning
Old 22nd November 2020, 03:34 PM   #74
I suppose we all suffer from something, be it totally crazy, or totally deaf.
Now if I were the only one who felt as I do...
Old 22nd November 2020, 08:35 PM   #75
Most of us feel as we do
Some corroboration here:
Leaving a component on continuously will NOT properly form the caps!!! They need to discharge and recharge over multiple cycles to do this. And it is not best to simply turn the component on and off in quick succession. The caps retain charge for several hours once the component is turned off and need to discharge that voltage over the same time frame, which is why cycling on-off, on a daily basis, with an overnight to discharge is by far the best way to form caps.
Do electrolytic caps need burn in? | Audiogon Discussion Forum
  Reply to this post
Audio note kaisei capacitorsHide this!Advertise here!
Thread Tools
FA Audio Note Kaisei Caps eanee Swap Meet 3 1st March 2018 02:29 AM
vaious Audio Note capacitors patriz Swap Meet 2 23rd October 2015 09:14 PM
Audio Note Kaisei M Gregg Parts 1 28th June 2015 10:17 PM
FS: 2 pcs. Audio Note 0.47 uF silver capacitors mbede Swap Meet 2 8th December 2011 06:40 PM
FS: Audio Note UK Capacitors fas948 Swap Meet 0 8th April 2010 09:54 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
