Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Quad or Series/Parallel Resistors as an alternative to traditional power resistors
Old 31st March 2018, 02:09 PM   #31
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Originally Posted by Damon Hill View Post
How far do we have to go before hitting quantum noise? There's got to be a rock bottom somewhere!
--Damon
When I was learning about electronics from my father as a kid, he told me that -30 dB was something you could hear, but very quiet. -70 dB was a great noise floor. For years I believed that. Then I heard the difference that -90 or -100 could make and was shocked.
I don't know where the bottom is, but I keep trying to learn.
Old 31st March 2018, 03:17 PM   #32
DF96 is offline DF96  England
Originally Posted by lehmanhill
As anti is saying, I wonder if we wouldn't be better off using soldier mounting (vertical) for axial power resistors. The inductance might be a little higher, but I would expect the heat transfer from a vertical cylinder to be better than a horizontal one.
Better convection may help with power dissipation, but will make very little difference to any thermal distortion because for that you need to consider the instantaneous temperature changes of the resistive element, and that is some distance in thermal terms from the surface temperature.
Some of us might be shocked if you can demonstrate that you can genuinely and reliably hear down there, especially when not in a specially prepared 'quiet room'.
Old 31st March 2018, 03:31 PM   #33
EUVL is offline EUVL  Europe
Inspired by Samuel, who uses Beyschlag MELF in series-parallel in his low-distortion oscillator design :
My version of the G = 1000 low noise measurement amp (for Ikoflexer).
Patrick
xen-audio.com
Old 31st March 2018, 03:45 PM   #34
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
In modular DAC's vertical mounted standard resistors can exhibit a differential thermocouple effect due to the heat flowing preferentially out the board end. Many standard semiconductor manufacturing materials are not pure metals and you can get 10-100uV/C in some cases from even bond wire terminations.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 31st March 2018, 05:17 PM   #35
lehmanhill's Avatar
Very interesting. I had not thought about that.
Old 31st March 2018, 05:18 PM   #36
lehmanhill's Avatar
Patrick
Patrick,
I should have given you credit for starting me on this configuration. A diyaudio friend pointed me to your posts and you pointed me to Groner. Thanks. It has been an interesting learning experience.
Jac
Old 31st March 2018, 05:24 PM   #37
lehmanhill's Avatar
I would be shocked as well. I am not claiming to be able to hear -90 dB sounds. But the first time I heard a modern amp, not knowing any of it's specs, I was amazed how clear and detailed the music sounded. One of the characteristics of that amp was a noise floor about -90 dB. Since then, I have found some level of correlation between a low noise floor (among other things) and sweet sounding music. That's all.
Old 1st April 2018, 02:30 PM   #38
Low noise floor may mean that the designer knew what he was doing, which will have benefits in other aspects of performance. The connection is thus correlation rather than causal.
Old 13th September 2018, 10:27 PM   #39
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
I believe the EAR 834p uses a quad for the plate resistors.
Just an example of commercial use of this concept “in the wild”
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 14th September 2018, 07:51 AM   #40
trobbins is offline trobbins  Australia
trobbins's Avatar
Perhaps.
A plate resistor typically has a circa 500V rating requirement, which often dictates a 2W resistor at least. Maybe a 0.6W or 1W resistor with 350V rating is just acceptable. That quad of resistors look a bit like 0.6W style - so maybe that quad is more about spreading heat-dissipation, and economics of manufacture by using a common part on the pcb.
Quad or Series/Parallel Resistors as an alternative to traditional power resistorsHide this!Advertise here!
Bass Driver & LPads, Series & Parallel Resistors lordtarquin Multi-Way 4 7th October 2017 05:58 AM
Best Way To Install Parallel Resistors Winston Smith Parts 14 16th October 2015 05:55 PM
Add (or delete) resistors in series with opamp's power supply rails ygg-it Chip Amps 8 30th November 2014 04:07 AM
Quad II: Which resistors? johnm Tubes / Valves 5 19th September 2006 01:52 PM
Opinions about Caddock MV series power resistors MEnsing Parts 6 16th October 2002 09:33 AM
