Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Copper RCA connector
Old 2nd September 2019, 05:50 PM   #11
Mark Tillotson is offline Mark Tillotson
Originally Posted by DF96 View Post
Yes, copper is too soft and so will make a poor connector. I am going to guess that OFC copper will be particularly soft and so particularly useless for this application. It is unlikely that you will be able to buy such an item, as nobody should be daft enough to make one.
I can see two ground lugs on those connectors.
You can work-harden copper. Makes a huge difference to its properties (of course there is absolutely no point using oxygen free copper, work-hardened metals have higher resistivity anyway). Typically copper alloys are used for machined parts, not pure copper, such as tellurium copper and beryllium copper (used for spring contacts).
The ground lugs are machined flat to be soldered directly onto a PCB I think (like SMA connectors). Alas a solid copper connector is going to be impossible to solder without a large powerful iron - the plastic gaskets should be removed before soldering of course.
Old 2nd September 2019, 05:55 PM   #12
As I understand it, adding tellurium to copper will
1. make it more radioactive - but not dangerously so
Almost immeasurably so - many orders of magnitude less radioactive than bananas for instance.
Old 2nd September 2019, 07:06 PM   #13
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Has anybody made RCA connectors out of bananas?
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 2nd September 2019, 07:28 PM   #14
Galu is offline Galu  Scotland
"The radiation exposure from consuming one banana is approximately 1% of the average daily exposure to radiation."
Sorry, I just had to check on Wikipedia!
Old 3rd September 2019, 04:33 PM   #15
DF96 is offline DF96  England
People have made and tested interconnects made out of banana. They were almost indistinguishable from copper.
Old 3rd September 2019, 05:04 PM   #16
zalive is offline zalive
Well at least we heard some use bananas on speaker cables...
Old 3rd September 2019, 05:17 PM   #17
JMFahey's Avatar
Weapons are currently made out of iron/steel, but we must remember our History: they were earlier made out of Bronze (hint: Bronze Age) or even ***COPPER***
By the way, these are Chinese copper swords.
If they make swords out of copper, why wouldn´t they make simple RCA connectors?
Earlier ones from stone or wood, but maybe at a primeval age we made them out of Bananas, why not?
So learning to defend against them can save your life someday.
YouTube
Old 4th September 2019, 10:01 AM   #18
Early copper would have contained lots of impurities so would have been stronger than modern copper.
There is no good reason to make an RCA connector out of copper. There are good reasons for making wire out of copper. People should not confuse these two quite different applications of conductors.
Old 4th September 2019, 11:19 AM   #19
davidsrsb is offline davidsrsb  Malaysia
In the copper age, there was no attempt to refine the metal, so it would probably have been mixed with arsenic naturally, which is a much harder alloy
Copper RCA connectorHide this!Advertise here!
Copper plating with acid copper sulfate. Osvaldo de Banfield Construction Tips 17 19th September 2016 01:54 PM
WTB: Harmonic Tech Cyber-Link Copper or Digital Copper cable reaction Swap Meet 1 2nd July 2010 10:50 AM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 07:21 PM
Copper heatsink tweak - Thermaltake Copper Heatsinks Ruach Digital Source 16 23rd September 2006 10:59 PM
Finished my DIY Copper foil speaker cable, what connector to use? Guijs Everything Else 4 19th October 2005 10:31 PM
Copyright ©1999-2019 diyAudio
