Toroidal transformer
Wiring the secondaries in series or parallel are just regular connections to increase total voltage or current. If you want to build a dual PS using two bridges that configuration it is the best circuit you can implement IMHO. Doing so you would avoid any average current to be establish in the secondaries in case of an unbalanced current output. Doing a center tape configuration and just one bridge you could saturate the transformer under those circumstances.
