i just started using zetex parts which i find to be sonically better than run of the mil 327s that i've been using.
zetex sounds smoother and cleaner.
what of the transistor's spec promotes such behavior and which of the two zetex npns would you say would sound 'better' in an input duty of 50w amp?
http://www.mouser.com/ds/2/115/ZTX857-93446.pdf
vs
http://www.mouser.com/ds/2/115/ZTX851-90982.pdf
my guess is that 857 would sound cleaner with the lower output capacitance.
vs
Semiconductor brand has no effect on sonic qualities.i just started using zetex parts which i find to be sonically better than run of the mil 327s that i've been using.
Which behaviour?what of the transistor's spec promotes such behavior
Don´t know about "better" , not sure it even applies here, I´m quite certain both will sound exactly the same, to any human ear.and which of the two zetex npns would you say would sound 'better' in an input duty of 50w amp?
Not sure any human ear could pick one over the other or both over the transistor which was originally there.
Specially because most probably the "input transistor in a 50W amp" is inside a strong NFB loop which would tend to erase any microscopic difference which *might* have existed.
your guess is just that, a guess.my guess is that 857 would sound cleaner with the lower output capacitance.
You read some specs, and imagine what effect that might cause on the sound.
I bet any competent amp designer will have made his amp immune to such minor changes in a not-that-important parameter (at Audio frequencies).
I also bet that wiring , grounding or layout will have far more effect than that tiny variation you mentioned.
And again, Zetex is a competent Semiconductor Factory, I do not expect surprises from their plain , consumer grade transistors, they will work as well as all other established competitors.
Brand is not a parameter.
I guess i would pick the ztx851 because all good sounding transistors that i know have high fT (the 857 is 80M). Then there must be compromise somewhere for having Vce 300v. May be the 60vce of ztx851 has lower noise? But the Cob is unusually high. Hard to predict as i think i have never used Q with such parameters in input stage.
