Efco capacitors?
Does anyone know where to get this specific Efco capacitor? A friend of mine asked if I got a source for them but so far no luck.
It's because the cap is french : they full it with wine and meat with sauce :D ... we have even bigger fulled with assado : sounds organic with a lot of meat :cool:
I should show you the SIC SAFCO mica I have rated at 2500 volts ;) (I believe you can find some in the old tramways of Bueno-Aires :) )
I am shocked that they are so large for just .22 uF capacitance, even if they are rated 1000V.
Those are ooooolllldddddd, I bet you can get much better much more compact caps same specs.
Large? No, actually. The cap is only 25mm in diameter. Maybe the close up photo makes you think they are large. Have you seen the V-Cap, Jensen or Duelund that have the same specs? Those are what I called oversized.
Nasty Efco batch !
How about these babies :eek: ^^ ?
Those are early 70s if I'm not mistaken. Just stumbled across that batch of 30. They got some mad value drifts and mojo and the tone is quite lush and creamy :cool:
