Taking delivery of an old Sprauge TO-5 Tel-Ohmike cap analyzer at the end of the week. There are several caps in there that always seem to drift out of range so I'm looking for replacements. These were +or-2% paper dialectric caps.
One is a 2uF 400VDC cap that I have seen replaced with two 1uF 1% caps and the other is a 0.02uF 600VDC cap.
A quick look at both DigiKey and Mouser shows nothing like that in film caps. How do I go about sourcing appropriate parts to bring this unit back into spec?
Also where can I get some quality reference caps to do the final calibration?
BillWojo
BillWojo
According to the parts list, their 2% caps were caps chosen for value. In other words they bought a bunch of caps and measured them, then used only the ones within 2%. You can do the same, buy ten 0.02 caps and measure them, pick one close in value. In fact the 2uf cap, they even specify it was a pair of 1uf in parallel.
Manual:
http://www.mcmlv.org/Archive/TestEquipment/Sprague_TO5.pdf
I have the similar unit from Eico, an old 950B. Everyone made one of these bridges in the day. The readings are approximate at best.
Manual:
The Sprauge cap analyzer came in yesterday afternoon. I had a chance to look at it this afternoon and was amused by what the factory did for the two 1uF 2% caps. In their place was two 1 uF 10% caps with a parallel 0.1 uF cap. I guess they ran out of close tolerance caps and used what they had on hand. All Sprauge of course.
BillWojo
BillWojo
TubeSound is the go-to place for the set:
https://tubesound.com/parts-accessories/
I got a set for an Eico bridge - same values as the Tel-Ohm-Mikes. For the TO-6, he has all 5 caps, matched, for $43, free shipping.
It saved me some time in hunting/matching and ordering from three vendors...
- Design & Build
- Parts
- 2% caps to rebuild Sprauge TO-5 cap analyzer
