Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Resistors with same spec, but different size. Same?
Old 7th May 2017, 08:17 PM   #1
avanc is offline avanc
Default Resistors with same spec, but different size. Same?
Didnt know where to put this, but I have ordered resistors from different vendors for my diy amp. I noticed that some resistors are about half the size of others, but they have the same values (R, W, %).
They are the same type. Axial. Film.
Are they interchangeable? Whatever fits?
Sent fra min EVA-L09 via Tapatalk
Old 7th May 2017, 08:34 PM   #2
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yeah, should be, size variation usually indicates wattage, maybe sign of the times....... fake (new{s}) resistors haha
Old 7th May 2017, 09:26 PM   #3
Dan Thomas is offline Dan Thomas  Canada
Quite likely the spec on the max voltage, voltage dependency and/or temperature coefficients differ.
For the most part they should be interchangeable though it can make a difference in some situations. In an audio amp the feedback resistor connecting the output to the input stage is critical and should be of high quality. (The voltage across the resistor causes it heat up changing the resistance.)
Cheers Dan
Old 7th May 2017, 09:45 PM   #4
Conrad Hoffman is offline Conrad Hoffman  United States
There are newer series of resistors that have high power ratings in smaller packages. They have to run hotter as a result. In many situations it won't matter, but I tend to stick with the tried and true, and then derate that. +1 on feedback networks. Whatever imperfections your feedback divider has, those will get impressed on the amp. Not only the series resistor, but the resistor (and cap, if present) to ground.
I may be barking up the wrong tree, but at least I'm barking!
Old 7th May 2017, 10:20 PM   #5
rayma is offline rayma  United States
As I think NP has mentioned, the NFB network is best made up of several identical series resistors,
each equal to the value of the R to ground. This gives the least thermally induced distortion, since all
behave the same and drop identical voltages. That is, if you use a 10k feedback, and a 1k to ground,
then the 10k should be made of ten series 1k resistors. All eleven resistors should be identical,
and all should have the same power rating. The unity gain capacitor is a real can of worms, though.
It's best to avoid that and use a servo instead.
Old 10th May 2017, 11:36 AM   #6
davidsrsb is offline davidsrsb  Malaysia
Is that Wattage at the same ambient temperature?
Old 10th May 2017, 03:20 PM   #7
I ordered just by looking at the w, r, % specs. Don't know about the other parameters, but I guess they can't possibly measure the same in all situations.
What i'm wondering is if it matters. If so, are there any other spec than w, r, % that should be taken a look at?
Old 10th May 2017, 05:01 PM   #8
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
It really is dependent on exactly how the resistor is used.
In some places it wont matter but in other places it can be critical.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 10th May 2017, 05:07 PM   #9
I see. Looks like I have overlooked the obvious; resistors too shape the output.
Well, the BOM of the amplifier just specify w, r, %. So I dont know which other values to compare or look for better qualities.
Old 10th May 2017, 05:19 PM   #10
The temperature coefficient as has already been mentioned. If in doubt use the larger resistors
Resistors with same spec, but different size. Same?Hide this!Advertise here!
What size gate resistors on power supply for Treo ssx 2000? kevamor Car Audio 23 3rd September 2015 07:21 AM
Will baffle size affect sealed enclosure size? PhilEV Construction Tips 6 27th February 2015 08:48 PM
PIONEER SPEC 1 SPEC 4 Like New Ninja77 Swap Meet 0 4th June 2014 11:21 AM
UK spec versus US Spec moggi1964 Tubelab 11 7th February 2014 03:42 PM
WTB: a couple of 1.8K Ohm high spec resistors jives11 Swap Meet 0 21st September 2007 08:02 AM
Copyright ©1999-2019 diyAudio
