Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
SMD trimmer resistor old alphanumeric markings?
Thread Tools
Old 19th April 2017, 03:25 PM   #1
multi-volti is offline multi-volti  United States
multi-volti's Avatar
Default SMD trimmer resistor old alphanumeric markings?
I have some older SMD trimmer resistors (late '90's) that have 2-character alphanumeric markings.
This format doesn't seem to be a practice used by current brands.
For example, I have some marked Y 3. Sample of 1 measured 3.3k.
'Normal' marking one could read might be 303 or 3 3 if I concluded that was probsbly a 3 k 10 or 20% part.
Does this ring a bell for anyone? 3.9 mm x 3.1 mm x 1.4 mm, open kind of construction, slotted metal rotator which is connected to wiper also (not insulated!).
I went through Digikey & Mouser catalog links...
Yeah, I can just measure them but I don't want to give up that easily. There is trivial info to be found!
Murray
Old 19th April 2017, 03:30 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Have you a pic of it?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 20th April 2017, 02:09 AM   #3
Not yet, but I will do so.
Murray
  Reply to this post
SMD trimmer resistor old alphanumeric markings?Hide this!Advertise here!
Thread Tools
Which way - trimmer resistor? Cintronic Analog Line Level 4 11th March 2017 12:26 PM
Recommend SMD resistor mtl777 Parts 22 31st August 2016 08:02 PM
Power Resistor markings JammyBStard Parts 4 3rd February 2011 10:46 PM
Strange (to me) resistor schematic markings sepulchre Parts 5 5th October 2008 03:16 PM
How to replace trimmer pot with fixed resistor? kptseng Solid State 9 8th August 2008 04:29 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
