Resistor Values for LINEAR Ladder Attenuator (not series Attenuator)
PRR
Joined 2003
24 positions means 23 resistors. Linear means all-equal.
1,000,000 Ohms / 23 = 43,478 Ohms.
43,200 is a Standard Value in E96 (1%).
43,000 is a Standard Value in E24 (5%).
Buy twenty-three for mono, forty-six for stereo.
NOTE that a 24-position switch will not naturally have a "center position". The alternative is to strap two poles on one end, work it as a 23 position, and buy 22 (or 44) 45,454 Ohm resistors.
Reactions: 1 user
Thanks jazbo8, the site has a calculator for series and shunt, can the shunt calculator be used for Ladder (parallel)?
My understanding is that they are different, see attached.
Does Fig. 2 show what you call a ladder attenuator? Then you also can use PRR's calculation: The upmost pair gets values of 43k2 on the left hand and (23 x 43k2=) 993k6 on the right hand side, the 2nd pair 2 x 43k2 and 22 x 43k2 etc., until you end with 23 x 43k2 and 43k2 for the pair at the bottom.
Best regards!
the calculator you opened shows series and shunt.
Can't you see that series is your FIG. 1 and shunt is your FIG. 3?
Why do you want/need a linear law?
Why do you want/need "ladder" type?
Do you know why you want/need those?
Do you know what they offer that is an advantage over other types?
Thanks all and to close this off.
Firstly, my apologies PPR, your calculation was right I was just confused when you said buy 23 resistors.
Kay your responce makes sense so will build a protype and see how it goes!
Scotjplin, series attenuators put the resistors in series so as you go up the stack, each resistor adds more noise to the circuit and this is compounding. Although ladder are more complex they do have a better result, which is why most volume attenuators (log) use this configuration.
Happy days, will let you know how it goes!
..............series attenuators put the resistors in series so as you go up the stack, each resistor adds more noise to the circuit and this is compounding. Although ladder are more complex they do have a better result, which is why most volume attenuators (log) use this configuration..............
the noise you refer to is dependant on the resistance.
If you have a 10k resistor it has the same noise as 10off 1k resistors.
Put a vol pot in there with a 10k resistance and it has the same effect as the two resistors that would be above and below the wiper that add up to that 10k
A vol pot whether linear or log law generates the same noise when they are both attenuating by the same amount.
A series switcher and a ladder switcher have exactly the same effect on the noise they each create.
If all of the above were of metal type then all would have the same noise.
A carbon track vol pot will have more noise than any of the metal types.
I suspect a plastic type resistive track will have some intermediate noise level compared to metal & carbon.
Here's what you are looking for, for 'ladder' resistor setup:
Call R1 the "input" resistor
Call R2 the "output" resistor.
If Linear, 24 steps from 100% to 0%:
STEP ATTN-RATIO R1 R2
0 0.00% - 100.00
1 4.35% 4.35 95.65
2 8.70% 8.70 91.30
3 13.04% 13.04 86.96
4 17.39% 17.39 82.61
5 21.74% 21.74 78.26
6 26.09% 26.09 73.91
7 30.43% 30.43 69.57
8 34.78% 34.78 65.22
9 39.13% 39.13 60.87
10 43.48% 43.48 56.52
11 47.83% 47.83 52.17
12 52.17% 52.17 47.83
13 56.52% 56.52 43.48
14 60.87% 60.87 39.13
15 65.22% 65.22 34.78
16 69.57% 69.57 30.43
17 73.91% 73.91 26.09
18 78.26% 78.26 21.74
19 82.61% 82.61 17.39
20 86.96% 86.96 13.04
21 91.30% 91.30 8.70
22 95.65% 95.65 4.35
23 100.00% 100.00 -
Essentially R1 + R2 ≡ 100 kΩ (say)
To get the attenuation, R1 = 100 kΩ • ratio.
Then, 100 kΩ - R1 is R2
Not at all very difficult, really. Indeed, this is also the easiest way to compute log scale divider stacks. For the same "100 K input impedance" you'd just have:
dB RATIO R1 R2
0 0.00% - 100,000.00
-3 29.21% 29,205.00 70,795.00
-6 49.88% 49,881.00 50,119.00
-9 64.52% 64,519.00 35,481.00
-12 74.88% 74,881.00 25,119.00
-15 82.22% 82,217.00 17,783.00
-18 87.41% 87,411.00 12,589.00
-21 91.09% 91,087.00 8,913.00
-24 93.69% 93,690.00 6,310.00
-27 95.53% 95,533.00 4,467.00
-30 96.84% 96,838.00 3,162.00
-33 97.76% 97,761.00 2,239.00
-36 98.42% 98,415.00 1,585.00
-39 98.88% 98,878.00 1,122.00
-42 99.21% 99,206.00 794.00
-45 99.44% 99,438.00 562.00
-48 99.60% 99,602.00 398.00
-51 99.72% 99,718.00 282.00
-54 99.80% 99,800.00 200.00
-57 99.86% 99,859.00 141.00
-60 99.90% 99,900.00 100.00
-63 99.93% 99,929.00 71.00
-66 99.95% 99,950.00 50.00
-69 99.96% 99,965.00 35.00
So, there you be.
GoatGuy
