Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
I need a terminal to solder stuff to.  Do they make this part and what is it called?
Old 12th November 2016, 12:31 PM   #1
garybdmd is offline garybdmd  United States
Default I need a terminal to solder stuff to. Do they make this part and what is it called?
Hi, I have been building some amps and preamps, and some of my designs have everything soldered to panel mount components, (pots switches etc).
Basically, almost all of the circuit nodes fall on a terminal of a panel mount device, like a leg on a pot for example, but there are a few connections just hanging out in the air.
I was wondering if there is some type of terminal that can be mounted to solder some leads to. I am imagining maybe a nylon tube that you can attach to the faceplate with a screw, and has a solder post or screw you connect leads to on the other side?
I have included a drawing of what I'm thinking of of maybe there is something that mounts that just has terminal to solder to similar to the rectifier shown, only just terminals to solder to not interconnected.
Old 12th November 2016, 12:39 PM   #2
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Maybe something like
Lug,Quick Fit and Binding Post Terminal Strips: Keystone Electronics
Old 12th November 2016, 12:49 PM   #3
nec3 is offline nec3  Turkey
812 / 912 GP Series - Single Row Terminal Blocks | Marathon Special Products
Old 12th November 2016, 12:52 PM   #4
fred76 is offline fred76  Philippines
Insulated turret terminals.. Example of old ad with ceramic/teflon insulation:
http://www.diyaudio.com/forums/swap-...e-amp-etc.html
Old 12th November 2016, 02:27 PM   #5
Default thanks everyone
These all look like great ideas. I think I may search for some "insulated turret terminals" I can just drill a hole wherever I need. There are only about 3 or 4 areas on the circuit where this is needed, but this will really come in handy. Thanks everyone!
Old 12th November 2016, 05:15 PM   #6
DF96 is offline DF96  England
tag strip?
Old 12th November 2016, 05:29 PM   #7
CharlieLaub is offline CharlieLaub  United States
(solder) lug terminal strip.
Surplus Sales:
https://www.surplussales.com/ELECTRI...rmStrip-6.html
Tubes and More:
https://www.tubesandmore.com/product..._boards_strips
Ebay:
Solder Terminal Lugs | eBay
Etc.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 12th November 2016, 06:09 PM   #8
MitchMev is offline MitchMev
Yep I would probably go with terminal strips if you need more than one terminal in the same area. They also make some with single terminals if you need that.
Terminal Strips | All Electronics Corp.
Edit: Larger selection: http://www.mouser.com/Connectors/Ter...5g5u?P=1yztjf0
Old 12th November 2016, 07:49 PM   #9
Default This single terminal strip would come in handy
I could definitely use these here and there. About 50cents a piece. I may order some of these.
Old 13th November 2016, 04:46 AM   #10
454Casull is offline 454Casull  Canada
Definitely terminal blocks AKA barrier strips. The type that nec3 showed a picture of also have handy things like pre-made jumpers and whatnot.
I need a terminal to solder stuff to.  Do they make this part and what is it called?Hide this!Advertise here!
Just too much stuff, almost giving it away, part 3 planet10 Planet 10 hifi 19 21st December 2018 06:01 PM
Just too much stuff, almost giving it away, part 2 planet10 Planet 10 hifi 5 6th August 2015 12:15 AM
anyone know how to make a solder pot? Clipped Parts 5 28th May 2012 04:49 PM
WTB: JL Audio Slash Series Power Terminal Plastic Seperator Part RiLoWa Swap Meet 0 4th June 2011 03:30 AM
Can I solder to this 0.25" terminal or do I need to use a female quick disconnect? 454Casull Parts 5 24th February 2009 05:37 PM
Copyright ©1999-2019 diyAudio
